Hy guys!
I'm facing a problem since the last update: I'm frequently receiving the message that said the hub is overloaded. The problem seems to be some Yeelight lamps I have, and it is causing the problems with devices and automations not answering and radio fails. Most of my devices are Zigbee, I just have these Yeelight bulbs (13) and an IR blaster connected through wi-fi.
When I restart the hub, the lamps become irresponsible for almost an hour, but the message disappear after that, to return hours later.
Could somebody help me, please?
Follow the logs:
dev:42021-02-17 09:39:46.442 infoTelnet connection to Yeelight established
dev:92021-02-17 09:38:44.145 debugheartbeat- message sent...
dev:92021-02-17 09:38:44.145 debugts- ct:1613565524144, lhb: 1613565522327, age: 1817
dev:92021-02-17 09:38:44.144 debuggetReTry- reTryCount:0
dev:82021-02-17 09:38:44.109 debugheartbeat- message sent...
dev:82021-02-17 09:38:44.108 debugts- ct:1613565524108, lhb: 1613565522327, age: 1781
dev:82021-02-17 09:38:44.107 debuggetReTry- reTryCount:0
dev:52021-02-17 09:38:44.055 errorTelnet connect failed, trying again in 120 seconds...
dev:52021-02-17 09:38:44.055 debuggetReTry- reTryCount:190
dev:52021-02-17 09:38:44.054 debuginitialize error: No route to host (Host unreachable)
dev:132021-02-17 09:38:42.020 infoTelnet connection to Yeelight established
dev:72021-02-17 09:38:32.325 debuggetReTry- reTryCount:1
dev:72021-02-17 09:38:32.324 debugts- ct:1613565512324, lhb: 1613565181329, age: 330995
dev:72021-02-17 09:38:32.323 debuggetReTry- reTryCount:0
dev:62021-02-17 09:38:32.288 debugheartbeat- message sent...
dev:62021-02-17 09:38:32.287 debugts- ct:1613565512287, lhb: 1613565400093, age: 112194
dev:62021-02-17 09:38:32.283 debuggetReTry- reTryCount:0
dev:52021-02-17 09:38:32.261 debuggetReTry- reTryCount:189
dev:52021-02-17 09:38:32.260 debugts- ct:1613565512260, lhb: 1613543192269, age: 22319991
dev:52021-02-17 09:38:32.259 debuggetReTry- reTryCount:188
dev:42021-02-17 09:38:32.237 debuggetReTry- reTryCount:1
dev:42021-02-17 09:38:32.236 debugts- ct:1613565512236, lhb: 1613565093411, age: 418825
dev:42021-02-17 09:38:32.235 debuggetReTry- reTryCount:0
dev:32021-02-17 09:38:32.211 debuggetReTry- reTryCount:1
dev:32021-02-17 09:38:32.210 debugts- ct:1613565512210, lhb: 1613565187209, age: 325001
dev:32021-02-17 09:38:32.209 debuggetReTry- reTryCount:0
dev:22021-02-17 09:38:32.178 debugheartbeat- message sent...
dev:22021-02-17 09:38:32.177 debugts- ct:1613565512177, lhb: 1613565399932, age: 112245
dev:22021-02-17 09:38:32.177 debuggetReTry- reTryCount:0
dev:12021-02-17 09:38:32.153 debugheartbeat- message sent...
dev:12021-02-17 09:38:32.152 debugts- ct:1613565512152, lhb: 1613565399050, age: 113102
dev:12021-02-17 09:38:32.151 debuggetReTry- reTryCount:0
dev:132021-02-17 09:38:32.120 debuggetReTry- reTryCount:1
dev:132021-02-17 09:38:32.119 debugts- ct:1613565512119, lhb: 1613565187012, age: 325107
dev:132021-02-17 09:38:32.118 debuggetReTry- reTryCount:0
dev:122021-02-17 09:38:32.093 debugheartbeat- message sent...
dev:122021-02-17 09:38:32.092 debugts- ct:1613565512091, lhb: 1613565398959, age: 113132
dev:122021-02-17 09:38:32.091 debuggetReTry- reTryCount:0
dev:112021-02-17 09:38:32.052 debugheartbeat- message sent...
dev:112021-02-17 09:38:32.051 debugts- ct:1613565512051, lhb: 1613565461880, age: 50171
dev:112021-02-17 09:38:32.050 debuggetReTry- reTryCount:0
dev:102021-02-17 09:38:32.024 debugheartbeat- message sent...
dev:102021-02-17 09:38:32.023 debugts- ct:1613565512023, lhb: 1613565399056, age: 112967
dev:102021-02-17 09:38:32.022 debuggetReTry- reTryCount:0
dev:1392021-02-17 09:37:58.852 infoBanheiro - Sensor de Movimento is inactive
dev:112021-02-17 09:37:41.947 infoTelnet connection to Yeelight established
dev:82021-02-17 09:36:40.371 warnmethod telnetStatus of device Hall 1 ran for 342,583ms
dev:82021-02-17 09:36:40.362 infoTelnet connection to Yeelight established
dev:92021-02-17 09:36:40.299 warnmethod telnetStatus of device Bar 3 ran for 342,509ms
dev:92021-02-17 09:36:40.275 infoTelnet connection to Yeelight established
dev:62021-02-17 09:36:40.169 warnmethod telnetStatus of device Estar 4 ran for 310,024ms
dev:62021-02-17 09:36:40.161 infoTelnet connection to Yeelight established
dev:22021-02-17 09:36:39.978 infoTelnet connection to Yeelight established
dev:112021-02-17 09:36:38.957 errorTelnet connection dropped...
dev:112021-02-17 09:36:38.956 debuggetReTry- reTryCount:1
dev:132021-02-17 09:36:38.948 errorTelnet connection dropped...
dev:132021-02-17 09:36:38.947 debuggetReTry- reTryCount:1
dev:132021-02-17 09:36:38.946 debugtelnetStatus- error: send error: Broken pipe (Write failed)
dev:112021-02-17 09:36:38.946 debugtelnetStatus- error: send error: Broken pipe (Write failed)
dev:92021-02-17 09:36:32.561 debugheartbeat- message sent...
dev:92021-02-17 09:36:32.557 debugts- ct:1613565392557, lhb: 1613565246631, age: 145926
dev:92021-02-17 09:36:32.554 debuggetReTry- reTryCount:0
dev:82021-02-17 09:36:32.514 debugheartbeat- message sent...
dev:82021-02-17 09:36:32.510 debugts- ct:1613565392510, lhb: 1613565306762, age: 85748
dev:82021-02-17 09:36:32.507 debuggetReTry- reTryCount:0
dev:72021-02-17 09:36:32.466 debugheartbeat- message sent...
dev:72021-02-17 09:36:32.463 debugts- ct:1613565392462, lhb: 1613565181329, age: 211133
dev:72021-02-17 09:36:32.458 debuggetReTry- reTryCount:0
dev:62021-02-17 09:36:32.431 debugheartbeat- message sent...
dev:62021-02-17 09:36:32.431 debugts- ct:1613565392430, lhb: 1613565366894, age: 25536
dev:62021-02-17 09:36:32.430 debuggetReTry- reTryCount:0
dev:52021-02-17 09:36:32.397 debuggetReTry- reTryCount:189
dev:52021-02-17 09:36:32.393 debugts- ct:1613565392393, lhb: 1613543192269, age: 22200124
dev:52021-02-17 09:36:32.390 debuggetReTry- reTryCount:188
dev:42021-02-17 09:36:32.360 debuggetReTry- reTryCount:1
dev:42021-02-17 09:36:32.359 debugts- ct:1613565392359, lhb: 1613565093411, age: 298948
dev:42021-02-17 09:36:32.358 debuggetReTry- reTryCount:0
dev:32021-02-17 09:36:32.319 debugheartbeat- message sent...
dev:32021-02-17 09:36:32.316 debugts- ct:1613565392315, lhb: 1613565187209, age: 205106
dev:32021-02-17 09:36:32.313 debuggetReTry- reTryCount:0
dev:22021-02-17 09:36:32.302 debugheartbeat- message sent...
dev:22021-02-17 09:36:32.291 debugts- ct:1613565392290, lhb: 1613565188646, age: 203644
dev:22021-02-17 09:36:32.287 debuggetReTry- reTryCount:0
dev:12021-02-17 09:36:32.250 debugheartbeat- message sent...
dev:12021-02-17 09:36:32.249 debugts- ct:1613565392248, lhb: 1613565190725, age: 201523
dev:12021-02-17 09:36:32.247 debuggetReTry- reTryCount:0
dev:132021-02-17 09:36:32.204 debugheartbeat- message sent...
dev:132021-02-17 09:36:32.201 debugts- ct:1613565392200, lhb: 1613565187012, age: 205188
dev:132021-02-17 09:36:32.197 debuggetReTry- reTryCount:0
dev:122021-02-17 09:36:32.159 debugheartbeat- message sent...
dev:122021-02-17 09:36:32.156 debugts- ct:1613565392155, lhb: 1613565183505, age: 208650
dev:122021-02-17 09:36:32.152 debuggetReTry- reTryCount:0
dev:112021-02-17 09:36:32.116 debugheartbeat- message sent...
dev:112021-02-17 09:36:32.115 debugts- ct:1613565392114, lhb: 1613565190717, age: 201397
dev:112021-02-17 09:36:32.114 debuggetReTry- reTryCount:0
dev:102021-02-17 09:36:32.102 debugheartbeat- message sent...
dev:102021-02-17 09:36:32.093 debugts- ct:1613565392093, lhb: 1613565190746, age: 201347
dev:102021-02-17 09:36:32.090 debuggetReTry- reTryCount:0
dev:6732021-02-17 09:36:14.669 debugUnable to parse message
dev:6732021-02-17 09:36:13.603 debugUnable to parse message
dev:32021-02-17 09:36:08.975 errorTelnet connection dropped...
dev:32021-02-17 09:36:08.974 debuggetReTry- reTryCount:1
dev:32021-02-17 09:36:08.973 debugtelnetStatus- error: send error: Broken pipe (Write failed)
dev:42021-02-17 09:36:08.968 errorTelnet connection dropped...
dev:42021-02-17 09:36:08.968 debuggetReTry- reTryCount:1
dev:42021-02-17 09:36:08.966 debugtelnetStatus- error: send error: Broken pipe (Write failed)
dev:52021-02-17 09:36:08.951 errorTelnet connect failed, trying again in 120 seconds...
dev:52021-02-17 09:36:08.951 debuggetReTry- reTryCount:188
dev:52021-02-17 09:36:08.950 debuginitialize error: No route to host (Host unreachable)
dev:62021-02-17 09:36:06.978 infoTelnet connection to Yeelight established
dev:82021-02-17 09:35:06.831 infoTelnet connection to Yeelight established
dev:72021-02-17 09:35:05.788 errorTelnet connection dropped...
dev:72021-02-17 09:35:05.788 debuggetReTry- reTryCount:1
dev:72021-02-17 09:35:05.778 debugtelnetStatus- error: send error: Broken pipe (Write failed)
dev:1412021-02-17 09:35:01.118 infobuttonDown(button=1)
dev:1412021-02-17 09:35:01.081 infosendOpenCloseEvent(openClose=false) invertContact=false
dev:1412021-02-17 09:35:01.061 infomsgMap: [raw:4DC50100060800001000, dni:4DC5, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:1412021-02-17 09:35:00.918 infobuttonDown(button=1)
dev:1412021-02-17 09:35:00.894 infobuttonDown(button=1)
dev:1412021-02-17 09:35:00.883 infosendOpenCloseEvent(openClose=false) invertContact=false
dev:1412021-02-17 09:35:00.883 infobuttonDown(button=1)
dev:1412021-02-17 09:35:00.879 infomsgMap: [raw:4DC50100060800001000, dni:4DC5, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:1412021-02-17 09:35:00.870 infosendOpenCloseEvent(openClose=false) invertContact=false
dev:1412021-02-17 09:35:00.867 infomsgMap: [raw:4DC50100060800001000, dni:4DC5, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:1412021-02-17 09:35:00.855 infomsgMap: [raw:4DC50100060800001000, dni:4DC5, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:1412021-02-17 09:34:57.446 infobuttonPushed(button=1)
dev:1412021-02-17 09:34:57.399 infosendOpenCloseEvent(openClose=true) invertContact=false
dev:1412021-02-17 09:34:57.383 infomsgMap: [raw:4DC50100060800001001, dni:4DC5, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:92021-02-17 09:34:32.399 debugheartbeat- message sent...
dev:92021-02-17 09:34:32.398 debugts- ct:1613565272398, lhb: 1613565246631, age: 25767
dev:92021-02-17 09:34:32.398 debuggetReTry- reTryCount:0
dev:82021-02-17 09:34:32.374 debuggetReTry- reTryCount:1
dev:82021-02-17 09:34:32.373 debugts- ct:1613565272373, lhb: 1613564808781, age: 463592
dev:82021-02-17 09:34:32.372 debuggetReTry- reTryCount:0
dev:72021-02-17 09:34:32.349 debugheartbeat- message sent...
dev:72021-02-17 09:34:32.349 debugts- ct:1613565272348, lhb: 1613565181329, age: 91019
dev:72021-02-17 09:34:32.348 debuggetReTry- reTryCount:0
dev:62021-02-17 09:34:32.325 debuggetReTry- reTryCount:1
dev:62021-02-17 09:34:32.324 debugts- ct:1613565272323, lhb: 1613564878140, age: 394183
dev:62021-02-17 09:34:32.323 debuggetReTry- reTryCount:0
dev:52021-02-17 09:34:32.300 debuggetReTry- reTryCount:187
dev:52021-02-17 09:34:32.299 debugts- ct:1613565272299, lhb: 1613543192269, age: 22080030
dev:52021-02-17 09:34:32.298 debuggetReTry- reTryCount:186
dev:42021-02-17 09:34:32.264 debugheartbeat- message sent...
dev:42021-02-17 09:34:32.263 debugts- ct:1613565272263, lhb: 1613565093411, age: 178852
dev:42021-02-17 09:34:32.262 debuggetReTry- reTryCount:0
dev:32021-02-17 09:34:32.237 debugheartbeat- message sent...
dev:32021-02-17 09:34:32.236 debugts- ct:1613565272236, lhb: 1613565187209, age: 85027
dev:32021-02-17 09:34:32.235 debuggetReTry- reTryCount:0
dev:22021-02-17 09:34:32.206 debugheartbeat- message sent...
dev:22021-02-17 09:34:32.205 debugts- ct:1613565272204, lhb: 1613565188646, age: 83558
dev:22021-02-17 09:34:32.204 debuggetReTry- reTryCount:0
dev:12021-02-17 09:34:32.183 debugheartbeat- message sent...
dev:12021-02-17 09:34:32.182 debugts- ct:1613565272182, lhb: 1613565190725, age: 81457
dev:12021-02-17 09:34:32.178 debuggetReTry- reTryCount:0
dev:132021-02-17 09:34:32.161 debugheartbeat- message sent...
dev:132021-02-17 09:34:32.160 debugts- ct:1613565272160, lhb: 1613565187012, age: 85148
dev:132021-02-17 09:34:32.153 debuggetReTry- reTryCount:0
dev:122021-02-17 09:34:32.116 debugheartbeat- message sent...
dev:122021-02-17 09:34:32.115 debugts- ct:1613565272114, lhb: 1613565183505, age: 88609
dev:122021-02-17 09:34:32.114 debuggetReTry- reTryCount:0
dev:112021-02-17 09:34:32.090 debugheartbeat- message sent...
dev:112021-02-17 09:34:32.089 debugts- ct:1613565272089, lhb: 1613565190717, age: 81372
dev:112021-02-17 09:34:32.088 debuggetReTry- reTryCount:0
dev:102021-02-17 09:34:32.023 debugheartbeat- message sent...
dev:102021-02-17 09:34:32.022 debugts- ct:1613565272022, lhb: 1613565190746, age: 81276
dev:102021-02-17 09:34:32.021 debuggetReTry- reTryCount:0
dev:92021-02-17 09:34:06.695 infoTelnet connection to Yeelight established
dev:52021-02-17 09:33:03.383 errorTelnet connect failed, trying again in 120 seconds...
dev:52021-02-17 09:33:03.383 debuggetReTry- reTryCount:186
dev:52021-02-17 09:33:03.382 debuginitialize error: No route to host (Host unreachable)
dev:72021-02-17 09:33:01.417 infoTelnet connection to Yeelight established
dev:22021-02-17 09:32:35.156 infoTelnet connection to Yeelight established
dev:92021-02-17 09:32:32.431 debuggetReTry- reTryCount:1
dev:92021-02-17 09:32:32.430 debugts- ct:1613565152430, lhb: 1613564808790, age: 343640
dev:92021-02-17 09:32:32.429 debuggetReTry- reTryCount:0
dev:82021-02-17 09:32:32.408 debuggetReTry- reTryCount:1
dev:82021-02-17 09:32:32.407 debugts- ct:1613565152407, lhb: 1613564808781, age: 343626
dev:82021-02-17 09:32:32.406 debuggetReTry- reTryCount:0
dev:72021-02-17 09:32:32.387 debugheartbeat- message sent...
dev:72021-02-17 09:32:32.386 debugts- ct:1613565152386, lhb: 1613565091137, age: 61249
dev:72021-02-17 09:32:32.380 debuggetReTry- reTryCount:0
dev:62021-02-17 09:32:32.356 debuggetReTry- reTryCount:1
dev:62021-02-17 09:32:32.355 debugts- ct:1613565152355, lhb: 1613564878140, age: 274215
dev:62021-02-17 09:32:32.354 debuggetReTry- reTryCount:0
dev:52021-02-17 09:32:32.322 debuggetReTry- reTryCount:187
dev:52021-02-17 09:32:32.321 debugts- ct:1613565152321, lhb: 1613543192269, age: 21960052
dev:52021-02-17 09:32:32.321 debuggetReTry- reTryCount:186
dev:42021-02-17 09:32:32.298 debugheartbeat- message sent...
dev:42021-02-17 09:32:32.298 debugts- ct:1613565152297, lhb: 1613565093411, age: 58886
dev:42021-02-17 09:32:32.297 debuggetReTry- reTryCount:0
dev:32021-02-17 09:32:32.271 debugheartbeat- message sent...
dev:32021-02-17 09:32:32.271 debugts- ct:1613565152270, lhb: 1613565095700, age: 56570
dev:32021-02-17 09:32:32.270 debuggetReTry- reTryCount:0
dev:22021-02-17 09:32:32.249 debuggetReTry- reTryCount:1
dev:22021-02-17 09:32:32.247 debugts- ct:1613565152247, lhb: 1613564877044, age: 275203
dev:22021-02-17 09:32:32.246 debuggetReTry- reTryCount:0
dev:12021-02-17 09:32:32.221 debugheartbeat- message sent...
dev:12021-02-17 09:32:32.220 debugts- ct:1613565152220, lhb: 1613565093369, age: 58851
dev:12021-02-17 09:32:32.219 debuggetReTry- reTryCount:0
dev:132021-02-17 09:32:32.184 debugheartbeat- message sent...
dev:132021-02-17 09:32:32.183 debugts- ct:1613565152183, lhb: 1613565095738, age: 56445
dev:132021-02-17 09:32:32.182 debuggetReTry- reTryCount:0
dev:122021-02-17 09:32:32.143 debugheartbeat- message sent...
dev:122021-02-17 09:32:32.142 debugts- ct:1613565152142, lhb: 1613565093278, age: 58864
dev:122021-02-17 09:32:32.141 debuggetReTry- reTryCount:0
dev:112021-02-17 09:32:32.094 debugheartbeat- message sent...
dev:112021-02-17 09:32:32.093 debugts- ct:1613565152093, lhb: 1613564994622, age: 157471
dev:112021-02-17 09:32:32.086 debuggetReTry- reTryCount:0
dev:102021-02-17 09:32:32.044 debugheartbeat- message sent...
dev:102021-02-17 09:32:32.033 debugts- ct:1613565152033, lhb: 1613564997317, age: 154716
dev:102021-02-17 09:32:32.022 debuggetReTry- reTryCount:0
dev:5462021-02-17 09:32:26.033 infoGaragem Externa is off [physical]
dev:512021-02-17 09:32:25.533 infoSala de Jantar is off [physical]
dev:412021-02-17 09:32:25.522 infoLavabo is off [physical]
dev:22021-02-17 09:31:33.216 errorTelnet connection dropped...
dev:22021-02-17 09:31:33.216 debuggetReTry- reTryCount:1
dev:22021-02-17 09:31:33.214 debugtelnetStatus- error: send error: Broken pipe (Write failed)
dev:52021-02-17 09:31:33.207 errorTelnet connect failed, trying again in 120 seconds...
dev:52021-02-17 09:31:33.207 debuggetReTry- reTryCount:186
dev:52021-02-17 09:31:33.206 debuginitialize error: No route to host (Host unreachable)
dev:72021-02-17 09:31:31.218 infoTelnet connection to Yeelight established
dev:62021-02-17 09:31:30.160 errorTelnet connection dropped...
dev:62021-02-17 09:31:30.153 debuggetReTry- reTryCount:1
dev:62021-02-17 09:31:30.145 debugtelnetStatus- error: send error: Broken pipe (Write failed)
dev:5472021-02-17 09:31:04.034 warnEvent interval INCORRECT, recovery mode (Normal) ACTIVE! If this is shown every hour for the same device and doesn't go away after three times, the device has probably fallen off and require a quick press of the reset button or possibly even re-pairing. It MAY also return within 24 hours, so patience MIGHT pay off.
dev:5472021-02-17 09:31:04.030 warnOne or several EXPECTED checkin events have been missed! Something MIGHT be wrong with the mesh for this device. Minutes since last checkin: 8459 (maximum expected 90)
dev:72021-02-17 09:30:58.851 warnmethod telnetStatus of device Hall 3 ran for 502,836ms
dev:72021-02-17 09:30:58.838 infoTelnet connection to Yeelight established
dev:92021-02-17 09:30:57.814 errorTelnet connection dropped...
dev:92021-02-17 09:30:57.813 debuggetReTry- reTryCount:1
dev:82021-02-17 09:30:57.799 errorTelnet connection dropped...
dev:82021-02-17 09:30:57.798 debuggetReTry- reTryCount:1
dev:82021-02-17 09:30:57.796 debugtelnetStatus- error: send error: Broken pipe (Write failed)
dev:92021-02-17 09:30:57.790 debugtelnetStatus- error: send error: Broken pipe (Write failed)
dev:92021-02-17 09:30:32.506 debugheartbeat- message sent...
dev:92021-02-17 09:30:32.505 debugts- ct:1613565032505, lhb: 1613564808790, age: 223715
dev:92021-02-17 09:30:32.504 debuggetReTry- reTryCount:0
dev:82021-02-17 09:30:32.477 debugheartbeat- message sent...
dev:82021-02-17 09:30:32.476 debugts- ct:1613565032476, lhb: 1613564808781, age: 223695
dev:82021-02-17 09:30:32.475 debuggetReTry- reTryCount:0
dev:72021-02-17 09:30:32.451 debuggetReTry- reTryCount:1
dev:72021-02-17 09:30:32.450 debugts- ct:1613565032450, lhb: 1613564372177, age: 660273
dev:72021-02-17 09:30:32.449 debuggetReTry- reTryCount:0
dev:62021-02-17 09:30:32.421 debugheartbeat- message sent...
dev:62021-02-17 09:30:32.420 debugts- ct:1613565032419, lhb: 1613564878140, age: 154279
dev:62021-02-17 09:30:32.419 debuggetReTry- reTryCount:0
dev:52021-02-17 09:30:32.398 debuggetReTry- reTryCount:185
dev:52021-02-17 09:30:32.395 debugts- ct:1613565032395, lhb: 1613543192269, age: 21840126
dev:52021-02-17 09:30:32.395 debuggetReTry- reTryCount:184
dev:42021-02-17 09:30:32.373 debugheartbeat- message sent...
dev:42021-02-17 09:30:32.371 debugts- ct:1613565032371, lhb: 1613564939412, age: 92959
dev:42021-02-17 09:30:32.370 debuggetReTry- reTryCount:0
dev:32021-02-17 09:30:32.347 debugheartbeat- message sent...
dev:32021-02-17 09:30:32.345 debugts- ct:1613565032345, lhb: 1613564939556, age: 92789
dev:32021-02-17 09:30:32.345 debuggetReTry- reTryCount:0
dev:22021-02-17 09:30:32.314 debugheartbeat- message sent...
dev:22021-02-17 09:30:32.313 debugts- ct:1613565032313, lhb: 1613564877044, age: 155269
dev:22021-02-17 09:30:32.312 debuggetReTry- reTryCount:0
dev:12021-02-17 09:30:32.293 debugheartbeat- message sent...
dev:12021-02-17 09:30:32.287 debugts- ct:1613565032287, lhb: 1613564940378, age: 91909
dev:12021-02-17 09:30:32.286 debuggetReTry- reTryCount:0
dev:132021-02-17 09:30:32.269 debugheartbeat- message sent...
dev:132021-02-17 09:30:32.268 debugts- ct:1613565032268, lhb: 1613564966377, age: 65891
dev:132021-02-17 09:30:32.262 debuggetReTry- reTryCount:0
dev:122021-02-17 09:30:32.212 debugheartbeat- message sent...
dev:122021-02-17 09:30:32.211 debugts- ct:1613565032211, lhb: 1613564994297, age: 37914
dev:122021-02-17 09:30:32.205 debuggetReTry- reTryCount:0
dev:112021-02-17 09:30:32.129 debugheartbeat- message sent...
dev:112021-02-17 09:30:32.129 debugts- ct:1613565032128, lhb: 1613564994622, age: 37506
dev:112021-02-17 09:30:32.127 debuggetReTry- reTryCount:0
dev:102021-02-17 09:30:32.105 debugheartbeat- message sent...
dev:102021-02-17 09:30:32.104 debugts- ct:1613565032104, lhb: 1613564997317, age: 34787
dev:102021-02-17 09:30:32.097 debuggetReTry- reTryCount:0
dev:102021-02-17 09:29:57.384 warnmethod heartbeat of device Bar 2 ran for 325,365ms
dev:102021-02-17 09:29:57.373 infoTelnet connection to Yeelight established
dev:112021-02-17 09:29:54.699 warnmethod heartbeat of device Estar 3 ran for 322,649ms
dev:112021-02-17 09:29:54.689 infoTelnet connection to Yeelight established
dev:122021-02-17 09:29:54.358 warnmethod heartbeat of device Abajur ran for 322,261ms
dev:122021-02-17 09:29:54.352 infoTelnet connection to Yeelight established
dev:132021-02-17 09:29:26.453 infoTelnet connection to Yeelight established
dev:562021-02-17 09:29:09.894 infoSensor da Sala is inactive
dev:12021-02-17 09:29:00.439 infoTelnet connection to Yeelight established
dev:52021-02-17 09:28:58.939 errorTelnet connect failed, trying again in 120 seconds...
dev:52021-02-17 09:28:58.934 debuggetReTry- reTryCount:184
dev:52021-02-17 09:28:58.933 debuginitialize error: No route to host (Host unreachable)
dev:102021-02-17 09:28:56.928 infoTelnet connection to Yeelight established
dev:562021-02-17 09:28:44.806 infoSensor da Sala is active
dev:92021-02-17 09:28:32.393 debugheartbeat- message sent...
dev:92021-02-17 09:28:32.392 debugts- ct:1613564912392, lhb: 1613564808790, age: 103602
dev:92021-02-17 09:28:32.391 debuggetReTry- reTryCount:0
dev:82021-02-17 09:28:32.354 debugheartbeat- message sent...
dev:82021-02-17 09:28:32.353 debugts- ct:1613564912353, lhb: 1613564808781, age: 103572
dev:82021-02-17 09:28:32.352 debuggetReTry- reTryCount:0
dev:72021-02-17 09:28:32.325 debuggetReTry- reTryCount:1
dev:72021-02-17 09:28:32.324 debugts- ct:1613564912324, lhb: 1613564372177, age: 540147
dev:72021-02-17 09:28:32.323 debuggetReTry- reTryCount:0
dev:62021-02-17 09:28:32.299 debugheartbeat- message sent...
dev:62021-02-17 09:28:32.298 debugts- ct:1613564912298, lhb: 1613564878140, age: 34158
dev:62021-02-17 09:28:32.297 debuggetReTry- reTryCount:0
dev:52021-02-17 09:28:32.265 debuggetReTry- reTryCount:185
dev:52021-02-17 09:28:32.264 debugts- ct:1613564912263, lhb: 1613543192269, age: 21719994
dev:52021-02-17 09:28:32.263 debuggetReTry- reTryCount:184
dev:42021-02-17 09:28:32.239 debugheartbeat- message sent...
dev:42021-02-17 09:28:32.238 debugts- ct:1613564912238, lhb: 1613564875500, age: 36738
dev:42021-02-17 09:28:32.237 debuggetReTry- reTryCount:0
dev:32021-02-17 09:28:32.212 debugheartbeat- message sent...
dev:32021-02-17 09:28:32.211 debugts- ct:1613564912211, lhb: 1613564873014, age: 39197
dev:32021-02-17 09:28:32.210 debuggetReTry- reTryCount:0
dev:22021-02-17 09:28:32.182 debugheartbeat- message sent...
dev:22021-02-17 09:28:32.181 debugts- ct:1613564912181, lhb: 1613564877044, age: 35137
dev:22021-02-17 09:28:32.180 debuggetReTry- reTryCount:0
dev:12021-02-17 09:28:32.150 debugheartbeat- message sent...
dev:12021-02-17 09:28:32.149 debugts- ct:1613564912149, lhb: 1613564876792, age: 35357
dev:12021-02-17 09:28:32.148 debuggetReTry- reTryCount:0
dev:132021-02-17 09:28:32.122 debugheartbeat- message sent...
dev:132021-02-17 09:28:32.121 debugts- ct:1613564912121, lhb: 1613564873007, age: 39114
dev:132021-02-17 09:28:32.121 debuggetReTry- reTryCount:0
dev:122021-02-17 09:28:32.096 debugheartbeat- message sent...
dev:122021-02-17 09:28:32.095 debugts- ct:1613564912095, lhb: 1613564873025, age: 39070
dev:122021-02-17 09:28:32.094 debuggetReTry- reTryCount:0
dev:112021-02-17 09:28:32.058 debugheartbeat- message sent...
dev:112021-02-17 09:28:32.056 debugts- ct:1613564912056, lhb: 1613564901234, age: 10822
dev:112021-02-17 09:28:32.055 debuggetReTry- reTryCount:0
dev:102021-02-17 09:28:32.033 debugheartbeat- message sent...
dev:102021-02-17 09:28:32.027 debugts- ct:1613564912026, lhb: 1613564809656, age: 102370
dev:102021-02-17 09:28:32.020 debuggetReTry- reTryCount:0
dev:112021-02-17 09:28:21.275 infoTelnet connection to Yeelight established
dev:62021-02-17 09:27:58.191 infoTelnet connection to Yeelight established
dev:52021-02-17 09:27:52.983 errorTelnet connect failed, trying again in 120 seconds...
dev:52021-02-17 09:27:52.983 debuggetReTry- reTryCount:184
dev:52021-02-17 09:27:52.981 debuginitialize error: No route to host (Host unreachable)
dev:62021-02-17 09:27:50.965 infoTelnet connection to Yeelight established
dev:12021-02-17 09:26:50.860 warnmethod telnetStatus of device Bar 1 ran for 435,625ms
dev:12021-02-17 09:26:50.855 infoTelnet connection to Yeelight established
dev:22021-02-17 09:26:50.821 warnmethod telnetStatus of device Estar 2 ran for 435,579ms
dev:22021-02-17 09:26:50.817 infoTelnet connection to Yeelight established
