Hey everyone,
Having an issue here with the Hue Bridge Integration, the built-in one from Hubitat, specifically. I had previously used CoCoHue without problems, but seeing as it seems to have become integrated I thought I may as well move over last time I was doing some messing around.
The following week I noticed issues with the Zigbee radio dropping off on my C7, and found it reporting severe hub load, with the Hue integration being a high percentage of usage. So I removed the integration from the C7 and installed it on my C8, which has fewer devices attached. The problem moved, and now my C8 is experiencing severe hub load issues.
Trick being, there are only 21 lights on the Hue bridge. No other accessories, no cameras, no security stuff, so this shouldn't be the hard work for the hub that it appears to be, surely?
I offloaded all of my lighting (except for in-wall on/off modules) to Hue years ago as I found lights that provided Zigbee routing being turned off would really destabilise the mesh on Hubitat, and this has been a solid compromise ever since.
Can anyone offer any troubleshooting steps or insight into why this should be happening?
