I had a hard time finding anything that worked for my Leviton VRCZ4-M0Z. I downloaded drivers/apps but none worked for me. I modified this driver and app from Michael Philip Kaufman. The object "Button" was depreciated and, oddly, the codes were not the same as returned from my unit. It doesn't seem to actuate the green lights on the unit, and I don't know about the dimmer (I would NEVER use that feature) but here Are the changes I made to the driver and the app. (I pray this is the right context / location for this!)
- Leviton VRCZ4-M0Z Switch Mapper
- Author: Michael Philip Kaufman
- Date: 2018-06-02 modified 2022-12-05 TG
definition(
name: "Leviton VRCZ4-M0Z Switch Mapper",
namespace: "mpk",
author: "Michael Philip Kaufman",
description: "Map Leviton VRCZ4-M0Z Zone Controller buttons to any SmartThings-compatible loads",
category: "Convenience",
iconUrl: 'http://schemalive.com/vrcz4-m0z.png',
iconX2Url: 'http://schemalive.com/vrcz4-m0z.png'
preferences {
page(name: "selectButtons")
def selectButtons() {
dynamicPage(name: "selectButtons", title: "Leviton VRCZ4-M0Z Switch Mapper", uninstall: true, install:true) {
section {
// input "buttonDevice", "capability.button", title: "Controller", multiple: false, required: true
input "buttonDevice", "capability.pushableButton", title: "Controller", multiple: false, required: true
(1..4).each {
def buttonNum = it
section(title: "Button ${buttonNum} will control:") {
input "switches_${buttonNum}", "capability.switch", title: "Switches:", multiple: true, required: false
section(title: "Button ${buttonNum} LED Status Color (when on):") {
input "color_${buttonNum}", "enum", title: "Choose LED Color:", required: false, default: 1, multiple: false, options: [1: 'Green', 17: 'Orange']
section {
label(title: "Label this SmartApp", required: false, defaultValue: "Leviton VRCZ4-M0Z Switch Mapper")
def installed() {
initialize()
atomicState.installed = true
def updated() {
unsubscribe()
initialize()
def initialize() {
atomicState.dimmingNow = false
subscribe(buttonDevice, "button", buttonEvent)
// subscribe(buttonDevice, "level", levelEvent)
(1..4).each {
def devices = settings['switches_'+it]
// log.debug "Devices for Button ${it}: ${devices}"
if (devices) {
// log.debug "${devices.deviceNetworkId.join(',')}"
buttonDevice.setButton(it, devices.deviceNetworkId.join(','))
subscribe(devices, 'switch', updateLights)
buttonDevice.configure()
def configured() {
return buttonDevice
def buttonEvent(evt){
// log.debug "buttonEvent evt: ${evt}"
def data = parseJson(evt.data)
// log.debug "buttonEvent data: ${data} -- data.button: ${data.button} -- data.buttonNumber: ${data.buttonNumber}"
data.button = (data.button != null) ? data.button : data.buttonNumber
switch (data.button) {
case "0":
atomicState.dimmingNow = (data.status == "start") ? true : false
// log.debug "atomicState.dimmingNow set to ${atomicState.dimmingNow}"
if (atomicState.dimmingNow) {
startDimming(data.switch, data.direction)
break
case "1":
case "17":
log.debug "Turning ${data.status} switches for button 1"
(data.status == "on") ? switches_1.on() : switches_1.off()
break
case "2":
case "18":
log.debug "Turning ${data.status} switches for button 2"
(data.status == "on") ? switches_2.on() : switches_2.off()
break
case "3":
case "19":
log.debug "Turning ${data.status} switches for button 3"
(data.status == "on") ? switches_3.on() : switches_3.off()
break
case "4":
case "19":
log.debug "Turning ${data.status} switches for button 4"
(data.status == "on") ? switches_4.on() : switches_4.off()
break
default:
log.debug "Falling through to default case for buttonEvent() on event ${evt} with evt.data ${evt.data} parsed to ${data} with status ${data.status} for button ${data.button}"
break
(1..4).each {
settings['switches_'+it].each {
if(it.hasCommand('poll')) {
it.poll()
} else if (it.hasCommand('ping')) {
it.ping()
//settings['switches_'+it]*.poll()
return;
def startDimming(buttonNumber, direction) {
// log.debug "Starting dimming ${direction} for button #${buttonNumber}"
def increment = (direction == "up") ? 2 : -2
def buttonDevices = switches_1
def startLevels = switches_1*.currentValue("level")
switch (buttonNumber) {
case "2":
buttonDevices = switches_2
startLevels = switches_2.currentValue("level")
break
case "3":
buttonDevices = switches_3
startLevels = switches_3.currentValue("level")
break
case "4":
buttonDevices = switches_4
startLevels = switches_4.currentValue("level")
break
doDimming(buttonDevices, startLevels, increment)
def doDimming(buttonDevices, startLevels, increment) {
// log.debug "Dimming ${buttonDevices} from ${workingLevels} by ${increment}"
for (;
def newLevels = []
buttonDevices.eachWithIndex {device, i ->
def workingLevel = startLevels[i]
// log.debug "Current level for ${device} is ${workingLevel}"
workingLevel += increment
// log.debug "New level for ${device} is ${workingLevel}"
workingLevel = (workingLevel < 100) ? workingLevel : 100
workingLevel = (workingLevel > 0) ? workingLevel : 0
// log.debug "Final level for ${device} is ${workingLevel}"
device.setLevel(workingLevel)
newLevels << workingLevel
startLevels = newLevels
(1..1000).each {}
if (!atomicState.dimmingNow)
break
def updateLights(evt)
log.debug "updateLights evt = ${evt}"
log.debug "Button 1: ${switches_1*.currentValue('switch')}"
log.debug "Button 2: ${switches_2*.currentValue('switch')}"
log.debug "Button 3: ${switches_3*.currentValue('switch')}"
log.debug "Button 4: ${switches_4*.currentValue('switch')}"
def one = switches_1*.currentValue('switch').contains('on')
def two = switches_2*.currentValue('switch').contains('on')
def three = switches_3*.currentValue('switch').contains('on')
def four = switches_4*.currentValue('switch').contains('on')
buttonDevice.setLightStatus((one ? color_1 : 0),(two ? color_2 : 0),(three ? color_3 : 0) , (four ? color_4 : 0))
Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
for the specific language governing permissions and limitations under the License.
metadata {
// Automatically generated. Make future change here.
definition (name: "Leviton VRCZ4-M0Z Zone Controller", namespace: "mpk", author: "Michael Philip Kaufman") {
capability "Actuator"
capability "PushableButton"
capability "Configuration"
capability "Sensor"
attribute "associatedLoad", "STRING"
attribute "associatedLoadId", "STRING"
attribute "currentButton", "STRING"
attribute "numButtons", "STRING"
command "associateLoad", ["NUMBER"]
command "setButton", ["NUMBER", "STRING"]
command "getparamState"
command "setLightStatus"
fingerprint deviceId: "0x0100", inClusters:"0x85, 0x2D, 0x7C, 0x77, 0x82, 0x73, 0x86, 0x72, 0x91, 0xEF, 0x2B, 0x2C"
// fingerprint zw:L type:0100 mfr:001D prod:0702 model:0261 ver:0.02 zwv:2.97 lib:01
// fingerprint mfr: "001D", prod: "0702", model: "0261"
/preferences {
input "button1", "string", title: "Button 1 Network id", description: "button 1 network id", required: false
input "button2", "string", title: "Button 2 Network id", description: "button 2 network id", required: false
input "button3", "string", title: "Button 3 Network id", description: "button 3 network id", required: false
input "button4", "string", title: "Button 4 Network id", description: "button 4 network id", required: false
simulator {
status "button 1 pushed": "command: 2B01, payload: 01 FF"
status "button 2 pushed": "command: 2B01, payload: 02 FF"
status "button 3 pushed": "command: 2B01, payload: 03 FF"
status "button 4 pushed": "command: 2B01, payload: 04 FF"
status "button released": "command: 2C02, payload: 00"
tiles {
standardTile("button", "device.button", width: 6, height: 4) {
state "default", label: " ", icon: "http://schemalive.com/vrcz4-m0z.png", backgroundColor: "#ffffff"
// Configure button. Syncronize the device capabilities that the UI provides
standardTile("configure", "device.configure", inactiveLabel: false, decoration: "flat") {
state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
standardTile("getmyState", "device.switch", height: 2, width: 2, inactiveLabel: false, decoration: "flat") {
state "default", label:"Get My State", action:"getparamState"
main "button"
details (["button", "configure", "getmyState"])
// parse events into attributes
log.debug "Parsing '${description}'"
if (description.contains("command: 9100")) {
def result = handleManufacturerProprietary(description)
log.debug "${result}"
return result
def result = null
def cmd = zwave.parse(description, [0x26:1])
// def cmd = zwave.parse(description, [0x91: 1])
if (cmd) {
result = zwaveEvent(cmd)
log.debug "Parsed ${cmd} to ${result.inspect()} (${result}) from description ${description}"
} else {
log.debug "Non-parsed event: ${description}"
return result
def handleManufacturerProprietary(String description) {
// log.debug "Handling manufacturer-proprietary command: '${description}'"
def result = []
switch (description) {
case "zw device: ${device.deviceNetworkId}, command: 2B01, payload: 01 00 , isMulticast: true":
case "1":
// log.debug "Turning button #1 on"
updateState("currentButton", "1")
result << createEvent(name: "button", value: "on", data: [button: 1, status: "on"], isStateChange: true)
break
case "zw device: ${device.deviceNetworkId}, command: 2B01, payload: 15 00 , isMulticast: true":
case "5":
// log.debug "Turning button #1 off"
result << createEvent(name: "button", value: "off", data: [button: 1, status: "off"], isStateChange: true)
break
case "zw device: ${device.deviceNetworkId}, command: 2B01, payload: 02 00 , isMulticast: true":
case "2":
// log.debug "Turning button #2 on"
updateState("currentButton", "2")
result << createEvent(name: "button", value: "on", data: [button: 2, status: "on"], isStateChange: true)
break
case "zw device: ${device.deviceNetworkId}, command: 2B01, payload: 16 00 , isMulticast: true":
case "6":
// log.debug "Turning button #2 off"
result << createEvent(name: "button", value: "off", data: [button: 2, status: "off"], isStateChange: true)
break
case "zw device: ${device.deviceNetworkId}, command: 2B01, payload: 03 00 , isMulticast: true":
case "3":
// log.debug "Turning button #3 on"
updateState("currentButton", "3")
result << createEvent(name: "button", value: "on", data: [button: 3, status: "on"], isStateChange: true)
break
case "zw device: ${device.deviceNetworkId}, command: 2B01, payload: 17 00 , isMulticast: true":
case "7":
// log.debug "Turning button #3 off"
result << createEvent(name: "button", value: "off", data: [button: 3, status: "off"], isStateChange: true)
break
case "zw device: ${device.deviceNetworkId}, command: 2B01, payload: 04 00 , isMulticast: true":
case "4":
// log.debug "Turning button #4 on"
updateState("currentButton", "4")
result << createEvent(name: "button", value: "on", data: [button: 4, status: "on"], isStateChange: true)
break
case "zw device: ${device.deviceNetworkId}, command: 2B01, payload: 18 00 , isMulticast: true":
case "8":
// log.debug "Turning button #4 off"
result << createEvent(name: "button", value: "off", data: [button: 4, status: "off"], isStateChange: true)
break
default:
log.debug "Fell through to default switch case ${description}"
break
return result
def setButton(num, val) {
log.debug "Setting button${num} to ${val}"
updateState("button$num", val)
// Handle a button being pressed
def buttonEvent(button) {
// log.debug "Entering buttonEvent() for button ${button}..."
button = button as Integer
def result = []
// updateState("currentButton", "$button")
// handleManufacturerProprietary(button.toString())
if (button > 0) {
// update the device state, recording the button press
// log.debug "${device.displayName} button ${button} was pushed"
// log.debug "Turning button #${buttonToSwitch(button)} ${buttonToStatus(button)}"
updateState("currentButton", buttonToSwitch(button))
result << createEvent(name: "button", value: "off", data: [button: buttonToSwitch(button), status: buttonToStatus(button)], isStateChange: true)
// result << createEvent(name: "button", value: /*"pushed"*/ "button $button", data: [buttonNumber: button], descriptionText: "$device.displayName button $button was pushed", isStateChange: true)
else {
// log.debug "${device.displayName} button ${button} was released"
result << createEvent(name: "button", value: "default", descriptionText: "$device.displayName button was released", isStateChange: true)
return result
// Map button on/off to switch #
def buttonToSwitch(button)
return ((button < 5) ? button : button - 4).toString()
// Map button on/off to status
def buttonToStatus(button)
return (button < 5) ? "on" : "off"
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd)
// log.debug "BasicReport: ${cmd}"
def result = []
result << createEvent(name:"switch", value: cmd.value ? "on" : "off")
// For a multilevel switch, cmd.value can be from 1-99 to represent dimming levels
result << createEvent(name:"level", value: cmd.value, unit:"%", descriptionText:"${device.displayName} dimmed ${cmd.value==255 ? 100 : cmd.value}%")
return result
def zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
// log.debug "SwitchBinaryReport: ${cmd}"
def zwaveEvent(hubitat.zwave.commands.switchmultilevelv3.SwitchMultilevelReport cmd) {
// log.debug "SwitchMultilevelReport: ${cmd}"
def result = []
return result
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd) {
// log.debug "$device.displayName bzone button was pressed: ${cmd}"
createEvent(name: "button", value: "default", descriptionText: "$device.displayName bzone button was pressed", isStateChange: true)
def zwaveEvent(hubitat.zwave.commands.sceneactivationv1.SceneActivationSet cmd) {
// log.debug "Entering zwaveEvent handler for SceneActivationSet with cmd = ${cmd}"
// The controller likes to repeat the command... ignore repeats
if (state.lastScene == cmd.sceneId && (state.repeatCount < 4) && (now() - state.repeatStart < 2000)) {
// log.debug "Button ${cmd.sceneId} repeat ${state.repeatCount}x ${now()}"
state.repeatCount = state.repeatCount + 1
createEvent([:])
else {
// If the button was really pressed, store the new scene and handle the button press
state.lastScene = cmd.sceneId
state.lastLevel = 0
state.repeatCount = 0
state.repeatStart = now()
buttonEvent(cmd.sceneId)
// A scene command was received -- it's probably scene 0, so treat it like a button release
def zwaveEvent(hubitat.zwave.commands.sceneactuatorconfv1.SceneActuatorConfGet cmd) {
// log.debug "SceneActuatorConfGet: $cmd"
def zwaveEvent(hubitat.zwave.commands.sceneactuatorconfv1.SceneActuatorConfReport cmd) {
// log.debug "SceneActuatorConfReport: ${cmd}"
// log.debug "Scene ${cmd.sceneId} set to ${cmd.level}"
createEvent([:])
def zwaveEvent(hubitat.zwave.commands.scenecontrollerconfv1.SceneControllerConfReport cmd) {
// log.debug "Scene controller report: ${cmd}"
// log.debug "Group ${cmd.groupId} set to Scene ${cmd.sceneId}"
// createEvent([:])
// Configuration Reports are replies to configuration value requests... If we knew what configuration parameters
// to request this could be very helpful.
def zwaveEvent(hubitat.zwave.commands.configurationv1.ConfigurationReport cmd) {
// log.debug "Received configuration report ${cmd}"
createEvent([:])
// The VRC supports hail commands, but I haven't seen them.
def zwaveEvent(hubitat.zwave.commands.hailv1.Hail cmd) {
// log.debug "Hail command received"
createEvent([name: "hail", value: "hail", descriptionText: "Switch button was pressed", displayed: false])
// Update manufacturer information when it is reported
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
// log.debug "Manufacturer-specific report: ${cmd}"
if (state.manufacturer != cmd.manufacturerName) {
updateDataValue("manufacturer", cmd.manufacturerName)
createEvent([:])
// Association Groupings Reports tell us how many groupings the device supports.
// This equates to the number of buttons/scenes in the VRCZ
def zwaveEvent(hubitat.zwave.commands.associationv2.AssociationGroupingsReport cmd) {
// log.debug "Association grouping report: ${cmd}"
def response = []
// log.debug "${getDataByName("numButtons")} buttons stored"
if (getDataByName("numButtons") != "$cmd.supportedGroupings") {
updateState("numButtons", "$cmd.supportedGroupings")
// log.debug "${cmd.supportedGroupings} groups available"
response << createEvent(name: "numButtons", value: cmd.supportedGroupings, displayed: false)
response << associateHub()
else {
return response
def zwaveEvent(hubitat.zwave.commands.associationv2.AssociationReport cmd) {
// log.debug "Association report V2: ${cmd}"
def commands = []
def buttonlist = ['x', state.button1.split(','), state.button2.split(','), state.button3.split(','), state.button4.split(',')]
// log.debug "buttonlist: ${buttonlist}"
cmd.nodeId.each({// log.debug "AssociationReport: '${cmd}', hub: '$zwaveHubNodeId' reports nodeId: '$it' is associated in group: '${cmd.groupingIdentifier}'"
if((it != zwaveHubNodeId) && (!buttonlist[integer(cmd.groupingIdentifier)].contains(Integer.toHexString(it).toUpperCase())))
// log.debug "$it couldn't find " + Integer.toHexString(it).toUpperCase() + "in button ${cmd.groupingIdentifier}"
sendHubCommand(new hubitat.device.HubAction(zwave.associationV2.associationRemove(groupingIdentifier: cmd.groupingIdentifier, nodeId: it).format()))
def zwaveEvent(hubitat.zwave.commands.associationv1.AssociationReport cmd) {
// log.debug "Association report V1: ${cmd}"
def commands = []
cmd.nodeId.each({// log.debug "AssociationReport v1: '${cmd}', hub: '$zwaveHubNodeId' reports nodeId: '$it' is associated in group: '${cmd.groupingIdentifier}'"
commands << zwave.associationV1.associationRemove(groupingIdentifier: cmd.groupingIdentifier, nodeId: it).format()
// log.debug "Sending $commands"
return delayBetween(commands,100)
def zwaveEvent(hubitat.zwave.commands.switchmultilevelv1.SwitchMultilevelStartLevelChange cmd) {
// log.debug "Switch Multilevel Start Level Change v1: ${cmd}"
createEvent(name: "button", value: "on", data: [button: 0, status: "start", switch: "${state.currentButton}", direction: cmd.upDown == true ? "down" : "up"], isStateChange: true)
def zwaveEvent(hubitat.zwave.commands.switchmultilevelv1.SwitchMultilevelStopLevelChange cmd) {
// log.debug "Switch Multilevel Stop Level Change v1: ${cmd}"
createEvent(name: "button", value: "off", data: [button: 0, status: "stop", switch: "${state.currentButton}"], isStateChange: true)
// Handles all Z-Wave commands we don't know we are interested in
def zwaveEvent(hubitat.zwave.Command cmd) {
// log.debug "Default zwaveEvent handler: ${cmd}"
createEvent(descriptionText: "${device.displayName}: ${cmd}")
// createEvent([:])
// handle commands
// Create a list of the configuration commands to send to the device
def configurationCmds() {
// Always check the manufacturer and the number of groupings allowed
def commands = [
zwave.manufacturerSpecificV2.manufacturerSpecificGet().format(),
zwave.associationV1.associationGroupingsGet().format()
commands = commands + associateHub()
// Reset to sceneId 0 (no scene) initially to turn off all LEDs.
// commands << zwave.sceneActuatorConfV1.sceneActuatorConfReport(dimmingDuration: 255, level: 255, sceneId: 0).format()
// commands << zwave.sceneActuatorConfV1.sceneActuatorConfReport(dimmingDuration: 0, level: 255, sceneId: 1).format()
// commands << zwave.sceneActuatorConfV1.sceneActuatorConfReport(dimmingDuration: 0, level: 255, sceneId: 2).format()
// commands << zwave.sceneActuatorConfV1.sceneActuatorConfReport(dimmingDuration: 0, level: 255, sceneId: 3).format()
// commands << zwave.sceneActuatorConfV1.sceneActuatorConfReport(dimmingDuration: 0, level: 255, sceneId: 4).format()
// log.debug "configurationCmds: ${commands}"
delayBetween(commands)
def getparamState() {
// log.debug "Listing current parameter/attribute settings for ${device.displayName}..."
def cmds = []
sendHubCommand(new hubitat.device.HubAction("91001D0D01FF01180508D3"))
// log.debug "Sending $cmds to ${device.deviceNetworkId}..."
// log.debug "deviceNetworkId: ${device.deviceNetworkId}"
// log.debug "displayName: ${device.displayName}"
// log.debug "numButtons: ${state.numButtons}"
// log.debug "currentButton: ${state.currentButton}"
// log.debug "associatedLoad: ${associatedLoad}"
// log.debug "associatedLoadId: ${associatedLoadId}"
// log.debug "capabilityCommands = ${getDeviceCapabilityCommands(device.capabilities)}"
def setLightStatus(one,two,three,four)
def hidden = ["0F", "00", "13", device.deviceNetworkId ]
def start = ["91", "00", "1D", "0D", "01", "FF"]
def end = ["00", "00", "0A"]
def light = integer(one) + (integer(two) << 1) + (integer(three) << 2) + (integer(four) << 3)
log.debug "Setting button-light statuses for ${device.displayName}..."
log.debug "one,two,three,four = $one,$two,$three,$four"
log.debug "HIDDEN: $hidden"
log.debug "START: $start"
log.debug "END: $end"
log.debug "LIGHT: $light"
def checksum = 255
hidden.each { checksum^=(integerhex(it)) }
log.debug "checksum, post-hidden: $checksum"
start.each { checksum^=(integerhex(it)) }
log.debug "checksum, post-start: $checksum"
end.each { checksum^=(integerhex(it)) }
log.debug "checksum, post-end: $checksum"
checksum^=light
log.debug "checksum, post-light: $checksum"
log.debug "${start.join()}${String.format("%02X",light)}${end.join()}${String.format("%02X",checksum)}"
sendHubCommand(new hubitat.device.HubAction("${start.join()}${String.format("%02X",light)}${end.join()}${String.format("%02X",checksum)}", hubitat.device.Protocol.ZWAVE))
// Configure the device
def configure() {
def cmd=configurationCmds()
// log.debug "Sending configuration: ${cmd}"
return cmd
// Associate a load with the button, or clear the association if nodeid = 0
// nodeId: a hex string, ie 4E for the Z-Wave node number
def associateLoad(String nodeId) {
// log.debug "Associating nodeId: ${nodeId}"
def node = integerhex(nodeId)
if (node != 0) {
updateState("associatedLoad", "1")
updateState("associatedLoadId", nodeId)
// log.debug "Node $nodeId associated with button 1"
else {
updateState("associatedLoad", "0")
// log.debug "No nodes associated with button 1"
configure()
// Associate the hub with the buttons on the device, so we will get status updates
def associateHub() {
def commands = []
def buttonlist = ['x', state.button1, state.button2, state.button3, state.button4]
// log.debug "Entering associateHub() for ${device.displayName}..."
// log.debug "state = ${state}"
// log.debug "zwaveHubNodeId = ${[zwaveHubNodeId]}"
// log.debug "buttonlist = ${buttonlist}"
for (def buttonNum = 1; buttonNum <= integer(getDataByName("numButtons")); buttonNum++) {
// log.debug "Loop for buttonNum = ${buttonNum}"
commands << zwave.sceneControllerConfV1.sceneControllerConfSet(groupId: buttonNum, sceneId: buttonNum, dimmingDuration: buttonNum).format()
commands << zwave.sceneControllerConfV1.sceneControllerConfSet(groupId: buttonNum+4, sceneId: buttonNum+4, dimmingDuration: buttonNum+4).format()
// commands << zwave.remoteAssociationActivateV1.remoteAssociationActivate(groupingIdentifier:buttonNum).format() //***** Parse error on cmd: 9100, payload: 1D 0C 0x 00
if(buttonlist[buttonNum]) {
// commands << zwave.associationV1.associationRemove(groupingIdentifier: buttonNum, nodeId: zwaveHubNodeId).format()
commands << zwave.associationV2.associationSet(groupingIdentifier: buttonNum, nodeId: [zwaveHubNodeId] /* + integerhex([zwaveHubNodeId]) /).format() //**** NumberFormatException on "001788280F07/5"
commands << zwave.associationV2.associationSet(groupingIdentifier: buttonNum+4, nodeId: [zwaveHubNodeId] /* + integerhex([zwaveHubNodeId]) /).format() //**** NumberFormatException on "001788280F07/5"
// commands << zwave.associationV2.associationSet(groupingIdentifier: buttonNum, nodeId: integerhex(buttonlist[buttonNum]) ).format() //***** NumberFormatException on "001788280F07/5"
commands << zwave.sceneControllerConfV1.sceneControllerConfGet(groupId:buttonNum).format()
commands << zwave.sceneControllerConfV1.sceneControllerConfGet(groupId:buttonNum+4).format()
commands << zwave.sceneActuatorConfV1.sceneActuatorConfGet(sceneId:buttonNum).format()
// commands << zwave.sceneActuatorConfV1.sceneActuatorConfSet(sceneId:buttonNum, level: 255, override: false).format()
// commands << zwave.sceneActuatorConfV1.sceneActuatorConfSet(sceneId:buttonNum, level: 32, dimmingDuration: 255, override: false).format()
commands << zwave.associationV2.associationGet(groupingIdentifier:buttonNum).format()
commands << zwave.associationV2.associationGet(groupingIdentifier:buttonNum+4).format()
// commands << zwave.associationV2.associationReport(groupingIdentifier:buttonNum).format()
// commands << zwave.associationV2.associationSpecificGroupReport(group:buttonNum).format()
// log.debug "commands: ${commands}"
return commands
// Update State
// Store mode and settings
def updateState(String name, String value) {
// log.debug "Updating ${name} to ${value}"
state[name] = value
device.updateDataValue(name, value)
// Get Data By Name
// Given the name of a setting/attribute, lookup the setting's value
def getDataByName(String name) {
state[name] ?: device.getDataValue(name)
- Builds a map of capability names to their supported commands.
@param a list of Capabilities.
@return a map of device capability -> supported commands.
def getDeviceCapabilityCommands(deviceCapabilities) {
// log.debug "Getting device capability commands: ${deviceCapabilities}"
def map = [:]
deviceCapabilities.collect {
map[it.name] = it.commands.collect{ it.name.toString() }
return map
//Stupid conversions
// convert a double to an integer
def integer(double v) {
return v.toInteger()
// convert a hex string to integer
def integerhex(String v) {
if (v == null) {
return 0
return v.split(',').collect { Integer.parseInt(it, 16) }
def integer(String v) {
if (v == null) {
return 0
return Integer.parseInt(v)
