After my hub auto shutdown (and then was operating slowly and I had slow motion triggered lights), I decided to start removing my changes as I hadn’t made backups before each change the previous day.
After removing custom code and devices, deleting Sonos (because I wondered whether 13 zones was too many), I kept going back and back but still had 2-3 second delays from motion to lights on. There were numerous reboots too (as I thought this might help).
This morning it’s back to being as responsive as it once was (it was still slow when I went to bed).
Could it be that there was some mesh rebuilding or other settling that needed to occur? If so, perhaps I didn’t need to keep removing all my additions and perhaps should have waited?
That would have to depend on what the problem is/was. Overnight, the Hub does maintenance tasks. Including purges of... purges of several things, including "ghost devices." It's difficult to diagnose from this chair, what happened on your hub. I would agree that you should move on to the next step and begin adding back. Do no more than half.. wait. Give it time to run out of.. whatever it ran out of.
Do not be too aggressive with reboots. I know it's tempting and add in some frustration... but no quicker than every 15 mins. There are only 4 DB on the hub, it's probably rewinding to an older one, perhaps finding that corrupted too, going back one more. Give it some time to recover.
One "problem" with a factory reset is the hub has to go through the registration cycle again... which means Support has to reset the keys/flags. In other words, you need a Support person handy, either way.
If boot without the radio stick doesn’t work, see if you can roll back to the previous platform version with the Hub updated tool.
You can get to it by http://[hub IP address]:8081
Replacing [hub IP address] with the actual IP address of your hub. It sounds like you may have a corrupted database that the hub isn’t able to rebuild and need to roll back to a backup database.
I’m reluctantly thinking that I should have two hubs, one that does the basics (lights, security, etc) and the other where I play with things that involve other’s code or unsupported devices) so that I don’t end up with this unreliability that impacts the core functions whilst I await support.
