@gopher.ny have you seen anything like this happen post migration from a C-7? Basically all of the settings apps are showing in the main applications UI. I'm assuming some sort of corruption? Should I try a soft reset?
Thanks!
Thanks!
It's not a database corruption, but those are supposed to stay invisible.
What is the hub id for the C8?
Edit: found the hub, looks like it's one of the beta ones with "developer" setting on. I'll add an endpoint to get rid of that in the next build... let's say /hub/advanced/clearHubPropertiesFile.
