Okay I was trying to add a repeat actions and ran into a bug in Rule Machine.
Steps:
- Click Create New Action
- Select Repeat Actions
- Select Repeat While Expression
- Select New Condition - Switch
- Select a Switch testing for ON
- Try to add a repeat interval - initially I was able to select and set 5 minutes now when I select repeat interval the drop down box says Click To Set with no options.
Initially when I did get an option for a time I then also selected Repeat Variable N Times and selected a value and stoppable. When I did that the Variable Repeat Interval I first selected vanished and I could not get it back. Now I think it's corrupt behind the scenes as I cannot get any repeat interval to set. I'm going to scrap and recreate the rule. At least it's not a long one.
