I've searched the Community & Google, as well as watched the Hubitat Video Guides and I can't find anything that resembles my problem.
What I want:
When the "Disarm" switch is turned off, and "Arm Away & Arm Stay" aren't turned On then "Disarm" turns back On again.
I've used switches instead of Buttons because from what I've seen you can't set Icons on buttons, and I'm a novice to Hubitat and not looking to mess with coding right now.
I've tried different versions of rules and If this Then that rules with delays (in Hubitat Rule Machine not the IFTTT App). I've tried rules with Modes and nothing is working as I want.
I know I'm missing something, but I'm not sure how to explain it to Hubitat so it works.
I hope this is what you are referring to as RM Code if not please point me in the right direction, I deleted the rule I was trying to accomplish because it makes my current button configuration not work right (Disarm is always On and won't turn Off). If you must see my failed attempts I suppose I could throw one together screenshot it then delete it again.
Thank you All, that did it, Wow "All" was the issue I missed that little switch...BUT...
The result was the same after changing "Any" to "All", but when I turned on the other three settings listed at the beginning of this post it all worked as expected , so my original settings with this new setting makes it work as desired.
It works as I desired, when Disarm is ON and I click any of the other two option Disarm turns OFF.
If Arm Away is ON and I click Disarm or Arm Stay, Arm Away turns OFF and vice versa for Arm Stay.
If Disarm is ON and I Click Disarm OFF, Disarm turns back ON.
This is what I wanted, and although I'm sure the method you provided should work alone I found it works with my previous settings to achieve the desired result.
Without the previous settings turned on it wasn't producing the desired result, so now my rule settings looks like this:
I actually would but being new to Hubitat and getting everything switched over from cloud based options, I'm taking baby steps.
I'll most likely try and turn this into a single rule, but I'm content for the moment...I just want to get my system back up and running locally which is great thus far; I also plan on digging into coding on this device to truly customize my dashboard, but like I said baby steps for now.
I'll be sure to reach out for your and the communities advice when I cross this road again, I like simplicity myself, and having 8 rules for 1 function is over kill.
