i tried to set a global variable in webcore, but when doing an action in the piston like location -> set variable i do not get the option to chose which variable, but only to tell the value of ‘device variable’; i remember that when using this in webcore over on smartthings i got the option to chose variable
thanks, that did change something, i now get the possibility to chose which variable to set, but i get a 'invalid variable 0' error message when running a simple piston setting either a local a global integer variable
