Set variable based on PWS status
I have an Ambient Weather Station which HE sees as a device. I would like to assign the current weather states to variables that could then be used in rules. HE does not recognize each individual sensor reading. Is there a workaround for this or what am I doing wrong?
Are they not usable under custom attributes in RM?
The Select device field is empty with no drop-down to choose from!
That is very odd I've never had that happen so can't help with that.
Can you use the custom attributes in a condition or are they also blank?
It just has the initial value the variable is defined with when the rule in being created
