Set the default on state for color bulbs
This looks like a near duplicate of your other post:
I would avoid posting the same thing in more than one area. If you want to "move" a post, Hubitat's forum software is a bit different from others you may be used to and you can edit the category and tag yourself the same way you'd edit your title.
However, you explained things differently here. It sounds like you're explaining what you want to happen, not what does happen. The suggestions in my other reply may still apply. But it sounds now like you might be looking for something more like Mode Lighting. With that, Motion Lighting, or even Rule Machine, you can specify level or (I think...haven't used this) color temperature by mode. There are some similar community options like a port of Circadian Lighting, but I don't know if anyone has had good luck with them.
