Attempting to set a Hub Variable with a connector > 225 chracters from an app, but keep getting an error that the variable is > 255 characters, however when initially setting or updating the variable from settings: HubVariables, it accepts more than 255 characters. Note: needed the connector to select it in the app.
This isn't possible, and there are not available methods (hence no documentation). You can access a local file from RM. I guess RM could call some method in a driver to pass a long string to it.
Thank you for posting this. I looked at it earlier and although it would definitely work, I was concerned the login overhead may rather high when processing a real time device command. Your thoughts?
I didn't optimize the login, but I was thinking that you could probably save the cookie value to state, and reuse it from there instead of requesting it each time (on my todo list to test, but...)
