Set Dimmer without turning on light
Is it possible to create a rule that will set the dimmer level without turning on the dimmer?
This needs to be supported in the dimmer hardware directly if you intent to have that level honored when the user turns it on physically, very few dimmers support this, and off hand I don't have a list of them...
Thanks for the very prompt reply Mike!
Some of the dimmers that support this is the GE Motion In-wall dimmer and the Leviton In-wall dimmer. Both have a "default level" which is used when the physical on paddle is pressed. In the case of the Leviton, there is a custom driver that exposes that functionality to the software so it can be changed via a rule. Supposed Zooz is adding this to the next version of their firmware as well.
Ok I was toying around with something in Rule Machine 4.0 and I need help understanding why this happens.
Here's the rule:
When I physically turn off the switch it runs the lights just dim again and don't turn off.
Here are the logs:
Thanks for helping this noob.
Is the fireplace dimmer in use by any other automations? If so, what do they do? If not, turn on logging for this rule and see what it thinks is happening. Something is turning it on and during this rule, though it's knows it's digital (some devices don't report this reliably) so I'm still not sure why it would happen.
You may also wish to just disable all automations associated with your dimmer and see if it sends anything odd/unexpected on its own when you change a level or turn it in or off via the device page in Hubitat. Unlikely, but...
You can see what other automations are affecting the switch in the edit device page under "used in". May I also ask, why do you have the "exit rule" for the dimmer rule? That's really unnecessary and may also be causing unknown complications.
I was having the same issue without it. I added to see if it would stop the issue. It did not.
I'm wondering if it's an issue with Hubitat. I don't have any other rules associated with the dimmer.
So I need more feedback. If you look my at trigger it shows switch turned to on is the trigger. But if you look at my logs below it looks like switch turned to off is triggering it as well.
dev:412019-08-31 03:24:37.138 pm infoFireplace Lights was set to 15% [digital]
dev:412019-08-31 03:24:37.135 pm infoFireplace Lights was turned on [digital]
app:4682019-08-31 03:24:36.969 pm infoAction: Dim: Fireplace Lights: 15
app:4682019-08-31 03:24:36.943 pm infoFireplace After Hours Triggered
app:4682019-08-31 03:24:36.925 pm infoFireplace After Hours: Fireplace Lights switch off
dev:412019-08-31 03:24:36.741 pm infoFireplace Lights was turned off [physical]
wait...so, you can't turn the device off with the rule disabled either?
If you pause the rule in RM, can you turn the device off by the physical switch? What type of device is this and what driver is it using?
Oh sorry for any confusion. If I pause the rule, everything operates normally. Lights go on and off with the switch.
But it appears that Hubitat is seeing the trigger "change" vs. "on" or "off". I hope that makes sense.
What do you have in the rule? Also, what type of device is this and what driver are you using?
The rule trigger is for Physical Switch Turns On.
It's on a Leviton Dimmer using Generic Zwave Dimmer
I tried on another Dimmer, which is a GE using Generic Zwave dimmer and the same thing is happening.
Leviton in wall dimmer? This device has a default level that you can set and you wouldn't need the rule at all.
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 * Adapted for Hubitat based on the Leviton Decora Z-Wave Plus Dimmer DTH developed by Jason Xia (jasonxh) for SmartThings
metadata {
    definition (name: "Leviton Z-Wave Plus Dimmer", namespace: "ryan780", author: "Ryan C.") {
        capability "Actuator"
        capability "Configuration"
        capability "Health Check"
        capability "Indicator"
        capability "Light"
        capability "Polling"
        capability "Refresh"
        capability "Sensor"
        capability "Switch"
        capability "Switch Level"
        attribute "loadType", "enum", ["incandescent", "led", "cfl"]
        attribute "presetLevel", "number"
        attribute "minLevel", "number"
        attribute "maxLevel", "number"
        attribute "fadeOnTime", "number"
        attribute "fadeOffTime", "number"
        attribute "levelIndicatorTimeout", "number"
        attribute "firmwareVersion", "string"
        command "low"
        command "medium"
        command "high"
        command "levelUp"
        command "levelDown"
    preferences {
        input name: "levelIncrement", type: "number", title: "In-App Level Increment",
                description: "1 - 100 (default $defaultLevelIncrement)", range: "1..100", defaultValue: defaultLevelIncrement,
                displayDuringSetup: false, required: false
        input type: "paragraph", element: "paragraph", title: "Device Preferences",
                description: "The following preferences are configuring the device behaviors. " +
                        "All of them are optional. Leave a preference empty to skip configuring it."
        input name: "loadType", type: "enum", title: "Load type",
                options: ["Incandescent (default)", "LED", "CFL"],
        input name: "indicatorStatus", type: "enum", title: "Indicator LED is lit",
                options: ["When switch is off (default)", "When switch is on", "Never"],
        input name: "presetLevel", type: "number", title: "Light turns on to level",
                description: "0 to 100 (default 0)", range: "0..100",
        input type: "paragraph", element: "paragraph", title: "",
                description: "0 = last dim level (default)\n1 - 100 = fixed level"
        input name: "minLevel", type: "number", title: "Minimum light level",
                description: "0 to 100 (default 10)", range: "0..100",
        input name: "maxLevel", type: "number", title: "Maximum light level",
                description: "0 to 100 (default 100)", range: "0..100",
        input name: "fadeOnTime", type: "number", title: "Fade-on time",
                description: "0 to 253 (default 2)", range: "0..253",
                description: "0 = instant on\n1 - 127 = 1 - 127 seconds (default 2)\n128 - 253 = 1 - 126 minutes"
        input name: "fadeOffTime", type: "number", title: "Fade-off time",
                description: "0 = instant off\n1 - 127 = 1 - 127 seconds (default 2)\n128 - 253 = 1 - 126 minutes"
        input name: "levelIndicatorTimeout", type: "number", title: "Dim level indicator timeout",
                description: "0 to 255 (default 3)", range: "0..255",
                description: "0 = dim level indicator off\n1 - 254 = timeout in seconds (default 3)\n255 = dim level indicator always on"
def installed() {
    log.debug "installed..."
    initialize()
    response(refresh())
def updated() {
    if (state.lastUpdatedAt != null && state.lastUpdatedAt >= now() - 1000) {
        log.debug "ignoring double updated"
        return
    log.debug "updated..."
    state.lastUpdatedAt = now()
    initialize()
    response(configure())
def configure() {
    def commands = []
    if (loadType != null) {
        commands.addAll(setLoadType(loadType))
    if (indicatorStatus != null) {
        commands.addAll(setIndicatorStatus(indicatorStatus))
    if (presetLevel != null) {
        commands.addAll(setPresetLevel(presetLevel as short))
    if (minLevel != null) {
        commands.addAll(setMinLevel(minLevel as short))
    if (maxLevel != null) {
        commands.addAll(setMaxLevel(maxLevel as short))
    if (fadeOnTime != null) {
        commands.addAll(setFadeOnTime(fadeOnTime as short))
    if (fadeOffTime != null) {
        commands.addAll(setFadeOffTime(fadeOffTime as short))
    if (levelIndicatorTimeout != null) {
        commands.addAll(setLevelIndicatorTimeout(levelIndicatorTimeout as short))
    log.debug "Configuring with commands $commands"
    commands
    def result = null
    def cmd = zwave.parse(description, [0x20: 1, 0x25:1, 0x26: 1, 0x70: 1, 0x72: 2])
    if (cmd) {
        result = zwaveEvent(cmd)
        log.debug "Parsed $cmd to $result"
    } else {
        log.debug "Non-parsed event: $description"
    result
def on() {
    def fadeOnTime = device.currentValue("fadeOnTime")
    def presetLevel = device.currentValue("presetLevel")
    short duration = fadeOnTime == null ? 255 : fadeOnTime
    short level = presetLevel == null || presetLevel == 0 ? 0xFF : toZwaveLevel(presetLevel as short)
    delayBetween([
            zwave.switchMultilevelV2.switchMultilevelSet(value: level, dimmingDuration: duration).format(),
            zwave.switchMultilevelV1.switchMultilevelGet().format()
    ], durationToSeconds(duration) * 1000 + commandDelayMs)
def off() {
    def fadeOffTime = device.currentValue("fadeOffTime")
    short duration = fadeOffTime == null ? 255 : fadeOffTime
    delayBetween([
            zwave.switchMultilevelV2.switchMultilevelSet(value: 0x00, dimmingDuration: duration).format(),
def setLevel(value, durationSeconds = null) {
    log.debug "setLevel >> value: $value, durationSeconds: $durationSeconds"
    short level = toDisplayLevel(value as short)
    short dimmingDuration = durationSeconds == null ? 255 : secondsToDuration(durationSeconds as int)
    sendEvent(name: "level", value: level, unit: "%")
    sendEvent(name: "switch", value: level > 0 ? "on" : "off")
    delayBetween([
            zwave.switchMultilevelV2.switchMultilevelSet(value: toZwaveLevel(level), dimmingDuration: dimmingDuration).format(),
    ], durationToSeconds(dimmingDuration) * 1000 + commandDelayMs)
def poll() {
    delayBetween(statusCommands, commandDelayMs)
def ping() {
    poll()
def refresh() {
    def commands = statusCommands
    commands << zwave.versionV1.versionGet().format()
    if (getDataValue("MSR") == null) {
        commands << zwave.manufacturerSpecificV1.manufacturerSpecificGet().format()
    for (i in 1..8) {
        commands << zwave.configurationV1.configurationGet(parameterNumber: i).format()
    log.debug "Refreshing with commands $commands"
    delayBetween(commands, commandDelayMs)
def indicatorNever() {
    sendEvent(name: "indicatorStatus", value: "never")
    configurationCommand(7, 0)
def indicatorWhenOff() {
    sendEvent(name: "indicatorStatus", value: "when off")
    configurationCommand(7, 255)
def indicatorWhenOn() {
    sendEvent(name: "indicatorStatus", value: "when on")
    configurationCommand(7, 254)
def low() {
    setLevel(10)
def medium() {
    setLevel(50)
def high() {
    setLevel(100)
def levelUp() {
    setLevel(device.currentValue("level") + (levelIncrement ?: defaultLevelIncrement))
def levelDown() {
    setLevel(device.currentValue("level") - (levelIncrement ?: defaultLevelIncrement))
private static int getCommandDelayMs() { 1000 }
private static int getDefaultLevelIncrement() { 10 }
private initialize() {
    // Device-Watch simply pings if no device events received for 32min(checkInterval)
    sendEvent(name: "checkInterval", value: 2 * 15 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID, offlinePingable: "1"])
private zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
    dimmerEvent(cmd.value)
private zwaveEvent(hubitat.zwave.commands.switchmultilevelv1.SwitchMultilevelReport cmd) {
private zwaveEvent(hubitat.zwave.commands.switchmultilevelv1.SwitchMultilevelStopLevelChange cmd) {
    response(zwave.switchMultilevelV1.switchMultilevelGet().format())
private zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
    if (cmd.value == 0) {
        switchEvent(false)
    } else if (cmd.value == 255) {
        switchEvent(true)
    } else {
        log.debug "Bad switch value $cmd.value"
private zwaveEvent(hubitat.zwave.commands.configurationv1.ConfigurationReport cmd) {
    def result = null
    switch (cmd.parameterNumber) {
        case 1:
            result = createEvent(name: "fadeOnTime", value: cmd.configurationValue[0])
            break
        case 2:
            result = createEvent(name: "fadeOffTime", value: cmd.configurationValue[0])
            break
        case 3:
            result = createEvent(name: "minLevel", value: cmd.configurationValue[0])
            break
        case 4:
            result = createEvent(name: "maxLevel", value: cmd.configurationValue[0])
            break
        case 5:
            result = createEvent(name: "presetLevel", value: cmd.configurationValue[0])
            break
        case 6:
            result = createEvent(name: "levelIndicatorTimeout", value: cmd.configurationValue[0])
            break
        case 7:
            def value = null
            switch (cmd.configurationValue[0]) {
                case 0: value = "never"; break
                case 254: value = "when on"; break
                case 255: value = "when off"; break
            result = createEvent(name: "indicatorStatus", value: value)
            break
        case 8:
            def value = null
                case 0: value = "incandescent"; break
                case 1: value = "led"; break
                case 2: value = "cfl"; break
            result = createEvent(name: "loadType", value: value)
            break
    result
private zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
    log.debug "manufacturerId:   $cmd.manufacturerId"
    log.debug "manufacturerName: $cmd.manufacturerName"
    log.debug "productId:        $cmd.productId"
    log.debug "productTypeId:    $cmd.productTypeId"
    def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
    updateDataValue("MSR", msr)
    updateDataValue("manufacturer", cmd.manufacturerName)
    createEvent([descriptionText: "$device.displayName MSR: $msr", isStateChange: false])
private zwaveEvent(hubitat.zwave.commands.hailv1.Hail cmd) {
    createEvent(name: "hail", value: "hail", descriptionText: "Switch button was pressed", displayed: false)
private zwaveEvent(hubitat.zwave.commands.versionv1.VersionReport cmd) {
    createEvent(name: "firmwareVersion", value: "${cmd.applicationVersion}.${cmd.applicationSubVersion}", displayed: false)
private zwaveEvent(hubitat.zwave.Command cmd) {
    log.warn "Unhandled zwave command $cmd"
private dimmerEvent(short level) {
    def result = null
    if (level == 0) {
        result = [createEvent(name: "level", value: 0, unit: "%"), switchEvent(false)]
    } else if (level >= 1 && level <= 100) {
        result = [createEvent(name: "level", value: toDisplayLevel(level), unit: "%")]
        if (!isNewFirmware && device.currentValue("switch") != "on") {
            // Don't blindly trust level. Explicitly request on/off status.
            result << response(zwave.switchBinaryV1.switchBinaryGet().format())
        } else {
            result << switchEvent(true)
    } else {
        log.debug "Bad dimming level $level"
    result
private switchEvent(boolean on) {
    createEvent(name: "switch", value: on ? "on" : "off")
private getStatusCommands() {
    def cmds = []
    if (!isNewFirmware) {
        // Even though SwitchBinary is not advertised by this device, it seems to be the only way to assess its true
        // on/off status.
        cmds << zwave.switchBinaryV1.switchBinaryGet().format()
    cmds << zwave.switchMultilevelV1.switchMultilevelGet().format()
    cmds
private short toDisplayLevel(short level) {
    level = Math.max(0, Math.min(100, level))
    (level == (short) 99) ? 100 : level
private short toZwaveLevel(short level) {
    Math.max(0, Math.min(99, level))
private int durationToSeconds(short duration) {
    if (duration >= 0 && duration <= 127) {
        duration
    } else if (duration >= 128 && duration <= 254) {
        (duration - 127) * 60
    } else if (duration == 255) {
        2   // factory default
    } else {
        log.error "Bad duration $duration"
        0
private short secondsToDuration(int seconds) {
    if (seconds >= 0 && seconds <= 127) {
        seconds
    } else if (seconds >= 128 && seconds <= 127 * 60) {
        127 + Math.round(seconds / 60)
    } else {
        log.error "Bad seconds $seconds"
        255
private configurationCommand(param, value) {
    param = param as short
    value = value as short
    delayBetween([
            zwave.configurationV1.configurationSet(parameterNumber: param, configurationValue: [value]).format(),
            zwave.configurationV1.configurationGet(parameterNumber: param).format()
    ], commandDelayMs)
private setFadeOnTime(short time) {
    sendEvent(name: "fadeOnTime", value: time)
    configurationCommand(1, time)
private setFadeOffTime(short time) {
    sendEvent(name: "fadeOffTime", value: time)
    configurationCommand(2, time)
private setMinLevel(short level) {
    sendEvent(name: "minLevel", value: level)
    configurationCommand(3, level)
private setMaxLevel(short level) {
    sendEvent(name: "maxLevel", value: level)
    configurationCommand(4, level)
private setPresetLevel(short level) {
    sendEvent(name: "presetLevel", value: level)
    configurationCommand(5, level)
private setLevelIndicatorTimeout(short timeout) {
    sendEvent(name: "levelIndicatorTimeout", value: timeout)
    configurationCommand(6, timeout)
private setLoadType(String loadType) {
    switch (loadType) {
        case "Incandescent (default)":
            sendEvent(name: "loadType", value: "incandescent")
            return configurationCommand(8, 0)
        case "LED":
            sendEvent(name: "loadType", value: "led")
            return configurationCommand(8, 1)
        case "CFL":
            sendEvent(name: "loadType", value: "cfl")
            return configurationCommand(8, 2)
private setIndicatorStatus(String status) {
    switch (indicatorStatus) {
        case "When switch is off (default)":    return indicatorWhenOff()
        case "When switch is on":               return indicatorWhenOn()
        case "Never":                           return indicatorNever()
private boolean getIsNewFirmware() { device.currentValue("firmwareVersion") ==~ /1\.2\d/ }
Try using that driver instead. If you notice, when you first asked this question i said this was possible using certain dimmer and leviton is one of them. :slight_smile:
Thanks, but is this by time?
The rule has the condition if it's between 8:30 pm and Sunrise it sets dim level to 15. Any other time it's regular.
You can have the default level be 15 and then if the time is between sunrise and 8:30 pm and the level =15, set it to 100. Then you're not relying on the physical switch to be the trigger but the switch level being =15.
Sounds like a good work around for that dimmer. I have a couple of others that are not Leviton that I'd like to get the rule working on. Maybe @bravenel can chime in on what the issue with the rule might be.
Thanks for your help Ryan!!
It does look like that is happening. I'll look into it...
Bruce, it's the weekend! A holiday one at that!
Thanks for looking in to this. I'm amazed at the response from the Hubitat team. Simply awesome.
And Ryan, don't think I'm not grateful for what you offered as well. Thank you for giving your insight.
I can confirm there is a bug in RM. Good catch!
