Hello,
I am new to HE and I would be grateful if anyone can assist me resolving an issue I am having with rule machine event:
I have sengled model: E12-N1E control type: zigbee multicolor, I created a rule for this device however, the set color is not available from all other commands.
Oh that's odd! And you've not even chosen which bulb yet so it can't be that it thinks the bulb won't do it! What version do you have on your hub and are you using the latest Rule Machine (not the one called "legacy")
Try setting up (additionally) a Virtual RGBW Light device and see if that adds the options. Maybe the hub thinks you don't have any devices that can do colour, for some reason
Here's mine, this is what you're meant to be offered:
Rule machine only offers options that are supported by available devices. If select color is not an available option, that probably means that the driver that was selected for the Sengled bulb is not the right one.
Go to your device screen, select the Sengled bulb and scroll down to driver.
Make sure that the driver selected is the āSengled Element Color plusā. It probably selected the āSengled Element plusā driver instead.
Thank you very much for your assistance. I changed the device type in the configuration and the color module popped out. I just migrated from smartthings and need to learn more about hubitat.
Sebastien, Thank you sir. I had it configured it automatically by the system when I paired it for the first time. I changed the type in the configuration and everything is good now. I appreciate your help and your explanation.
