Set bulb brightness based on another bulb/dimmer
I have a dimmer switch in our guest room and would like the bedside lamp to always match the dimmer switch volume. Is this possible? Is there a built in app to do it...intuitively? Or would it be a series of Rules Machine rules?
EXACTLY what I was looking for. Thank you very much.
You can also do this via Rule Machine being one dimmer’s ā€œchangeā€ the trigger event, and the action defined to ā€œtrackā€ the event dimmer in the second dimmable device.
(The Track option appears once you select the Dim option.)
