Sensors show Temp in EZ dashboard when I select something else
I'm fairly sure this just happened in the newest hub update as this used to display properly.
Yesterday after updating to 2.4.4.151, I noticed that my EZ Dashboards show temperature for both my
  • Airthings Tile on which I selected Short Term Radon Average
  • Aqara Temp/Pressure/Humid devices for which I selected pressure
So I gone to edit the dashboard, and the proper attribute is selected, but it still shows temp.
Is anyone else having this issue?
Is it something I did or something with the hub update?
Not sure what caused it, but what I would try is toggling it to a different attribute, and then go back into the tile and change it back to what it should be. If it is permanently stuck on temp no matter what you choose for an attribute, you could even try changing the template away from attribute to something else, like temp or humidity, and then back to the attribute template.
Thanks for the response.
  • Airthings Device: Editing as you noted did not help. After several tries with different permutations, I realized the device type has changed to "Multi-Sensor" instead of "Air Quality." When I changed it back to Air Quality, and select the Short Term Radon measurement, it correctly shows on the EZ Dash tile. So this issue with the Airthings Device is solved.
  • Aqara Temp/Pressure/Humid device: Similar to the Airthings, this device type got changed to "Multi-Sensor" which has Pressure as an option, but when selected pressure won't show. I selected a few of the other options for device type in the dropdown, however regardless of what I try, I can't get Pressure to show - it just keeps showing Temperature, no matter what attribute I select. Anyone gotten this device to report pressure on an EZ Dashboard?
I see this issue as well with the tank utility monitor. When I add the device to the EZ Dashboard it automatically picks it as a multi sensor and it shows temperature and never shows the second attribute. I am new to habitat but I find it strange that whether it's configured as multi sensor or temperature sensor the tile icon in the upper left always shows a thermometer. By the way the only way I can get it to show the attribute I want is to configure it as a temperature sensor and select the attribute I want to display. I wound up setting up two separate tiles so I could see both. I wonder if anyone can confirm this to be a known issue and if so when there may be a fix?
