The generic z-wave contact sensor supports these now.
Indeed, thank you very much!
Just changed my to this DH and they are working OK.
Thanks.
Anyone else still have issues even after updating to the Aeon device type? I still get quite a few misses on both open and closes. It was always slow to update in ST but now seems to miss some open/closes altogether?
This device was added to the Generic Z-Wave Contact Sensor driver a while ago so there's no need to use a custom driver...
Tried that one first and had the same experience.
I'm having an odd problem with one of these. On wakening the logs (see below) show repeat activity -any thoughts why? Both are paired as Generic Z-wave sensors. Seems to function ok otherwise. Any thoughts on how to solve this?
dev:4982018-11-07 03:22:23.715 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.613 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.512 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.469 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.408 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.378 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.360 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.349 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.303 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.263 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.242 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.238 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.160 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.153 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.042 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.030 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.934 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.728 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.719 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.707 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.626 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.559 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.514 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.452 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.391 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.339 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.327 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.317 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.256 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.245 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.160 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.126 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.844 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.744 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.733 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.643 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.633 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.622 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.567 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.546 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.481 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.403 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.358 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.171 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.942 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.872 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.713 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.655 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.631 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.577 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.514 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.506 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.493 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.437 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.355 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.343 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.278 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.265 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.255 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.158 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.076 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:19.746 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:19.336 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:19.329 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:19.225 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:19.166 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:19.068 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.935 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.857 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.805 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.794 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.682 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.580 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.558 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.485 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.442 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.363 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.345 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.307 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.295 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.285 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.265 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.251 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.231 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.185 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.140 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.130 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.039 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.916 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.785 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.644 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.579 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.564 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.549 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.502 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.497 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.381 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.348 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.322 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.282 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.226 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.192 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.189 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.082 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.997 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.984 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.948 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.926 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.901 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.829 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.690 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.640 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.518 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.409 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.285 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.210 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.103 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.030 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.018 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.016 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.999 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.990 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.970 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.850 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.825 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.815 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.805 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.698 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.676 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.666 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.621 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.507 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.368 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.334 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.224 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.197 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.185 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.016 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.006 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.968 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.832 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.819 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.815 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.804 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.680 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.406 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.357 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.336 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.306 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.225 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.132 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.121 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.028 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.997 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.976 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.869 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.848 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.795 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.785 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.774 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.728 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.680 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.667 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.632 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.600 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.521 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.507 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.430 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.421 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.408 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.375 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.304 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.293 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.237 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.224 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.213 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.182 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.090 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.016 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.005 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.922 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.872 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.804 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.794 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.783 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.744 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.741 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.684 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.653 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.618 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.597 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.579 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.564 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.502 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.493 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.438 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.437 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.362 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.346 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.316 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.295 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.169 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.078 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.011 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.942 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.826 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.816 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.805 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.753 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.714 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.686 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.572 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.541 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.478 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.476 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.390 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.378 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.343 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.335 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.314 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.226 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.145 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.083 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:10.814 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:10.783 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:10.703 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:10.496 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:10.376 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:10.200 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:09.823 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:09.684 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:09.623 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:09.475 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:09.415 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:09.383 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:09.260 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:08.793 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:08.753 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:08.700 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:08.666 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:08.645 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:08.609 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:08.501 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:08.500 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:07.755 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.653 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.575 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.498 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.433 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.431 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.365 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.356 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.286 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.262 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.214 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.179 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.076 debug Garage Inside Door Sensor woke up
So I am getting around to adding in my gate sensors. but all i get is this.... no open/close at all.. it is set to generic z wave contact sensor...
any ideas folks
I'm using the Generic Z-Wave Contact Sensor on my bay windows and my French Doors. It works great, except it's not very tolerant of fast open/closing actions. It likes two to three seconds in one state before changing to another. It's also really good to get the round magnet as closely alighted to the lit circle as possible. I also turned off the description Text logging
I have just moved from Homey to HE. Homey have a native app for the Strips sensors and there I also had the Tamper parameter. Is that something I also could get with Strips Guard in HE?
How does one tamper with a sealed device? I don't understand how this applies to a Sensative contact device . . .
“Strips will send a tamper alert if it detects that someone tries to wake up or manipulate Strips.”
Thanks for the link - it still doesn't make sense to me! Does waking the device up expose some vulnerability?
I'm not going to worry too much, thanks the slim design, mine are not accessible without opening the window - in which case I have the other problem (intrusion).
I don’t know but if you use the Guard to unlock or disarm you might want to know if someone tries to “hack” your device. I wouldn’t let a sensor disarm or unlock a device in my setup but someone might.
I have had a few times where my Danalock door lock didnt lock my door after the door was closed. I thought it was my Danalock who didnt work as espected.
Today I looked in the device log of the Strips Guard and saw no open or closed for around 08:45 was registrated. When I got home again at 09:05 both open and closed was registrated. It's like the Strips Guard was dead/sleeping at 08:45...
Has anybodey else seen this issue witht the Stips Guard?
Just got a replay from Sensative and it seems like I mounted the magnet wrong. I got a link with an instruction on magnet placement that wasent included in the package.
I had placed the magnet almost over the logo but the magnet should be outside the strip...
I will test for a few days now with the new placement but I hope it was as simple as that.
I found this that may help you.
- Always place Strips on the frame of the window or door when possible
- The magnet should be placed on the movable part whenever possible
- The rectangle magnet should be placed opposite and in line with the square end of Strips
- The ideal gap between Strips and the magnet is less than 15mm.
Got this link from the support earlier, https://sensative.com/guard. All info regarding mounting the Strips Guard is in there.
Just a quick follow up. Since mounting my Guard according to previous post it has been much much better.
