Sengled Smart LED Multicolor BR30 Bulb go offline
I have two Sengled Smart LED Multicolor BR30 Bulbs that go offline now and again. I think this might be happening after a hub update. To get them working again hey need to be removed and added back in. Any thoughts?
Thanks, Glenn
Where are the bulbs located relative to your Hub? Do you have any repeaters in the area? Do you have any ZLL (Hue) bulbs connected to the same hub as the Sengled? What other zigbee devices do you have connected to the Hub?
One of the bulbs is about 5 feet away in the same room the other is in the next room.
Have Hue Hub and Bulbs
Have a bunch of Cree Bulbs
Have 2 Sengled Smart LED with Touch Button A19 Bulb
Bunch of zigbee contact and motion sensors
Bunch of Peanut plugs
The only items that see to have an issue are the Sengled Smart LED Multicolor BR30's.
These may be your problem, as I believe these are known to be poor Zigbee HA repeaters. I replaced all of my Cree and GE Link bulbs with Sengled bulbs. Everything has been solid since.
If you don't want to part with the Crees, you can always reset them and put them on your Hue bridge.
