I have 9 of these and only one is doing this. Under the zigbee page it has thousands of msg when everything else has less than 100.
dev:652023-05-12 08:17:20.259 PMinfoskipped- attribute:0000, value:0000000015A0, status:null
dev:652023-05-12 08:17:20.255 PMdebugdescMap:[raw:0B8401070212000025A01500000000, dni:0B84, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:0000000015A0, clusterInt:1794, attrInt:0]
dev:652023-05-12 08:17:14.757 PMinfoskipped- attribute:0000, value:00000000159F, status:null
dev:652023-05-12 08:17:14.753 PMdebugdescMap:[raw:0B84010702120000259F1500000000, dni:0B84, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:00000000159F, clusterInt:1794, attrInt:0]
dev:652023-05-12 08:17:09.254 PMinfoskipped- attribute:0000, value:00000000159E, status:null
dev:652023-05-12 08:17:09.250 PMdebugdescMap:[raw:0B84010702120000259E1500000000, dni:0B84, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:00000000159E, clusterInt:1794, attrInt:0]
dev:652023-05-12 08:17:03.757 PMinfoskipped- attribute:0000, value:00000000159D, status:null
dev:652023-05-12 08:17:03.751 PMdebugdescMap:[raw:0B84010702120000259D1500000000, dni:0B84, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:00000000159D, clusterInt:1794, attrInt:0]
dev:652023-05-12 08:16:58.453 PMinfoskipped- attribute:0000, value:00000000159C, status:null
dev:652023-05-12 08:16:58.448 PMdebugdescMap:[raw:0B84010702120000259C1500000000, dni:0B84, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:00000000159C, clusterInt:1794, attrInt:0]
dev:652023-05-12 08:16:52.793 PMinfoskipped- attribute:0000, value:00000000159B, status:null
dev:652023-05-12 08:16:52.788 PMdebugdescMap:[raw:0B84010702120000259B1500000000, dni:0B84, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:00000000159B, clusterInt:1794, attrInt:0]
Zigbee logs
dev:652023-05-12 08:19:15.381 PMinfoprofileId:0x104, clusterId:0x702, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:84, lastHopRssi:-79
dev:652023-05-12 08:19:09.935 PMinfoprofileId:0x104, clusterId:0x702, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:84, lastHopRssi:-79
dev:652023-05-12 08:19:04.592 PMinfoprofileId:0x104, clusterId:0x702, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:84, lastHopRssi:-79
dev:652023-05-12 08:18:59.048 PMinfoprofileId:0x104, clusterId:0x702, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:84, lastHopRssi:-79
dev:652023-05-12 08:18:53.602 PMinfoprofileId:0x104, clusterId:0x702, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:88, lastHopRssi:-78
dev:652023-05-12 08:18:48.153 PMinfoprofileId:0x104, clusterId:0x702, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:92, lastHopRssi:-77
dev:652023-05-12 08:18:42.604 PMinfoprofileId:0x104, clusterId:0x702, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:84, lastHopRssi:-79
dev:652023-05-12 08:18:37.158 PMinfoprofileId:0x104, clusterId:0x702, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:84, lastHopRssi:-79
dev:652023-05-12 08:18:31.612 PMinfoprofileId:0x104, clusterId:0x702, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:84, lastHopRssi:-79
dev:652023-05-12 08:18:26.268 PMinfoprofileId:0x104, clusterId:0x702, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:88, lastHopRssi:-78
dev:652023-05-12 08:18:20.722 PMinfoprofileId:0x104, clusterId:0x702, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:84, lastHopRssi:-79
dev:652023-05-12 08:18:15.177 PMinfoprofileId:0x104, clusterId:0x702, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:84, lastHopRssi:-79
dev:652023-05-12 08:18:09.728 PMinfoprofileId:0x104, clusterId:0x702, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:84, lastHopRssi:-79
dev:652023-05-12 08:18:04.182 PMinfoprofileId:0x104, clusterId:0x702, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:88, lastHopRssi:-78
dev:652023-05-12 08:17:58.756 PMinfoprofileId:0x104, clusterId:0x702, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:84, lastHopRssi:-79
dev:652023-05-12 08:17:53.228 PMinfoprofileId:0x104, clusterId:0x702, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:84, lastHopRssi:-79
dev:652023-05-12 08:17:47.749 PMinfoprofileId:0x104, clusterId:0x702, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:84, lastHopRssi:-79
dev:652023-05-12 08:17:42.302 PMinfoprofileId:0x104, clusterId:0x702, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:80, lastHopRssi:-80
