I searched the forum and could not find anything on this topic, sorry if it has been discussed already.
I am having a hard time getting Sengled Extensions (no one has them local and Amazon shipping is a month out), so I got to thinking can I use a "full strip" as an extension and it works (I know, I'm slow sometimes). In reading more it looks like you can run up to 10 on 1 power supply/controller.
However I noticed while doing it that the color from one strip to the next is not 100% the same. Most colors are SUPER close to the exact same but SWMBO wants purple. Purple is just ever so slightly off from strip to strip, with some being closer than others (all Sengled LED strips at this point)
Is it normal for LED strip lights to differ off a little?
Also this adventure got me thinking about using "off brand" extensions, so my second question is
Can you "mix/match" different LED brands?
Which lead me to...if I connect two or more Sengled strips together I end up with spare power supply/controllers. Can I use them to power/control a different brand of LED strip?
I notice some strips are called 5050 and others having different names, but I do not know what those numbers mean. My guess is it is all in the design/build of the LED strip and as long as they have the same "pin outs" they should work.
Has anyone done this, or know way more than my limited knowledge on the subject?
Thanks for any insights.
