I have been using my setup for about a year in the current configuration. I have 8 zigbee sengled Element plus bulbs that have stayed connected pretty much the entire time. Recently I had a few that had issues and seemed to have disconnected. I have gone through the procedure to reconnect them (on off switch 10 times, then re-find the device on the zigbee page). This connection seems to last a day then the bulb disconnects again. This started a chain of events where I have had 3 of the bulbs disconnect now.
I went ahead and reset all the lights and reconnected them to my C-8 running the latest sw release. Now I am noticing slow updates from the lights (on/off status, level, ect.) which is messing with automation that use the (turn on only off items) which have worked well over the past few months. Has anyone seen this before? Any suggestions on debugging steps? ( have tried hitting configure on all the bulbs)
