Sengled E13-N11 Exposed Settings
Was hoping to keep driveway lights on for trick-or-treaters. The E13-N11 motion light bulb doesn't seem to have the option to stay on indefinitely, however the firmware seems to have an on_time and off_time setting that are not currently exposed by the built in driver. Not clear to me how long the on_time can be set to, and if its possible set this outside the device settings. Thoughts?
If you can point to where this is documented -- specifically, the Zigbee cluster, attribute, and values that do what you want -- it's likely this could be added to the driver.
This might be what I'm looking for:
binary({
cluster: 'manuSpecificSengledMotionSensor',
attribute: 'enableAutoOnOff',
description: 'Enable the PAR38 bulb to turn on automatically when motion is detected',
valueOn: [true, 0x01],
valueOff: [false, 0x00],
zigbeeCommandOptions: {manufacturerCode: 0x1160},
access: 'STATE_SET',
I realized I never just tried turning it on manually to see what happened..doh. Seems to work during the day, but I'll double check tonight, I suspect the auto on off is only used when the ambient light is low enough.
Tried at night, seems to stay on when turned on manaully even after triggering motion sensor.
