From what I have seen the Sengled bulbs are typically $20+. Today on Amazon I found four bulbs for $70 with a hub. Sure I don't need a Sengled hub but I figure it can be useful for updating firmware. Not a bad extra for one of the better prices I've seen on the bulbs.
https://www.amazon.com/Sengled-Multicolor-2000-6500K-Equivalent-Assistant/dp/B079ZQW1ST
I actually rather like their hub. It's really easy to understand the setup process and works well with both GH/Alexa. Good for a gift or for someone that might just be interest couple of smart bulbs. Good for a beginner system also. It's a better option then WiFi bulbs.
As a freebie with the best price I've seen on bulbs it's a definite buy for me.
It's terrible when people find deals and you are a bit short and can't take advantage of them. Can anyone lend me $69?
it's worse when i want to pull the trigger on a set so bad but I don't know where they'd go!
One of those outdoor string light thingies should work. I think they come in at least twenty four light strings. That should hold you for a while.
The 4 pack of white bulbs is on sale with an additional 15% coupon available making the price of each bulb only $8.29. And if you really want to go for cheap, there are used 4 packs listed for only $6.19 a bulb.
https://www.amazon.com/Sengled-Required-Equivalent-Assistant-SmartThings/dp/B072M5RT6L
Thanks for the heads up. I only use RGB bulbs so I donβt follow the prices of the adjustable white bulbs. Good info for those that use them.
i tend to pick up the Sylvania bulbs when I can get them for around $10 each. I have enough of them that it made sense to get a second hub rather than replace them all. Iβve been wanting to try out the Sengleds found it was a decent price point - particularly with the hub included for updates.
Now I just need to find a solution for GU-10 bulbs.
Just to clarify, those are just white bulbs. Not adjustable white. They're available in either Warm White or Daylight.
Ah, I definitely don't follow the price of those.
Thanks for the heads up on this, i did end up buying a 4 pack.
Also noticed Best Buy had 6.6 ft Sengled color strips for $38, so I picked up a few of those as well (i've been looking to replace some non-Zigbee white-only strips I have in the alcoves in my living room)
I'm curious to see if they dim lower than the Sylvanias. Guess I'll find out tomorrow.
The do not dim extremely low. That is one complaint I have about them. Definitely not as low as a Caseta dimmer.
Good deal on the Sengled Color Strips for $38 from Best Buy(unfortunately its $45 here). I regret not buying more when they were $35 during the fall.
They are nice to have as a backup in case a bulb gets flaky - also with the hub you can potentially update the bulb firmware I think but really any excuse to get more kit will do right?
