sendLocationEvent() changes types for Map to String? Why
I have a server App that serves Notifications like this:
Map Notification = [message: "Back Door Open"]
log.debug "type = " + getObjectClassName(Notification) // shows "type = java.util.LinkedHashMap"
sendLocationEvent(name:"NOTIFICATION", value: Notification, data: "Ring", descriptionText: "description you want", isStateChange: true)
I have a client App that subscribes to this and the first line in the event handler I get:
log.debug "type = " + getObjectClassName(evt.value) // shows "type = java.lang.String"
I am expecting to get a Map delivered in the handler just like I sent it.
I must be a bad researcher because I am looking for an explanation and cannot find one. Does someone know what is going on?
I'm not sure this is documented, but a good guess would be that the location object allows only strings for values on any event. (Groovy makes it easy to convert back and forth, though JSON would be a more conveniential intermediate format.)
Could you provide me a little more detail about "Groovy makes it easy to convert back and forth".
Here is an example, this being for the lightEffects attribute that is really a Map converted to/from JSON. It's just a device event/attribute, but doing this for a location event would be similar.
Bert, I really appreciate the help. It wasn't exactly like the example but it was close enough. I ended up with "def NotificationConverted = new groovy.json.JsonBuilder(Notification).toString()" in the Server and "def NotificationBack = new groovy.json.JsonSlurper().parseText(evt.value)" in the Client. You know this is totally straight forward right? NOT! LOL... thks again
