Is it really not possible to trigger a phone app notification (like the Notification app can do) from within Rule Machine?
My use case is I have a temp/vibration sensor on my dryer and when it stops I want to receive a notification. In Rule Machine I would like the trigger to be "no vibration for 1 minute" and then trigger a notification as long as the sensor temp is >25C or so to cover cases where the dryer is being loaded etc.
I realize a workaround would be to use a virtual switch, turn that switch on when the dryer stops, and use that switch in the Notification app to send the notification....
Or use some 3rd party thing (Pushover) but I would like to avoid this convolution if possible, otherwise they pile up and then you have a real mess.
What I actually find nice about this is that I get the notification on my phone from Hubitat 3-4 minutes before I get the notification from Tesla's own app (I suspect Tesla delays it on purpose -- but I want to know ASAP when the power is out).
@bravenel I did just now have a small difficulty when adding an action to activate a scene. In Rule-5.1, the outer Select label no longer says Activate Scene:
I understand your point. There is a bit of a learning curve with RM and though there have been significant improvements in the UI the emphasis has been on expanding functionality. However, it does have a certain internal logic and flow, and once you kinda figure it out you do develop kind of an RM "instinct."
FWIW, webCoRE also makes you choose a notification device, either a "default" in the parent app (really an artifact from SmartThings, where notifications are an action you perform at the account level) or on a particular action itself (like Rule Machine, both owning to the fact that notifications are regular commands in regular devices, like any other command, on Hubitat).
