Send message when device go offline
is there any way to get sms when my switches or other device go offline...
I personally use @bertabcd1234 's "Device Activity Check" App. It is simple and works very reliably.
Note: Hubitat's only official mechanism for true SMS messaging is to use their Twilio integration. However, you can also use numerous push notification solutions, including the Hubitat Mobile App, Pushover, and others.
I use Device Watchdog to do the same thing however as it's looking for activity it works best for devices with frequent temperature or battery level reporting.
If you look for activity of a switch then go away for the weekend or just don't use it for a few days, it will report the switch as offline since it didn't get switched, unless that switch is automated even while you're away.
thanks all for quick reply.. what i want is send sms to my mobile when my wall switch go offline.. why i want is.. if my wall switch trip by any reason and if i know early it can prevent fire or other big accident.
