SelectBlinds Automation Bridge (Matter) problems
I'm attempting to control a shade through the SelectBlinds Automation Bridge.
I have connected the bridge to HE via Matter, and it registered as "Generic Matter Bridge", with the connected shade registered as "Generic Component Window Shade".
The "Open" command works just fine, but the "Close" command moves the shade down about a quarter of an inch and stops.
Help! Thanks!
The "Configure" output from the bridge:
Turning on logging on the shade device (Generic Component Window Shade) and logging the output of that while operating the shade would probably be helpful here.
Alas, nothing appears in the Logs for any command given to the "Generic Component Window Shade" device. :frowning_face:
Should also note that pairing the bridge to Google Home works 100%, registering the shade correctly as well; if I could tie HE to GH in that direction, I'd be happy.
:point_up_2:
@bcopeland
OK, this is going to be a big "never mind" on my part - after some futzing around, I managed to connect the Bridge and shade back directly to Google Home, and then link a couple of HE "OPEN" and "CLOSE" virtual switches to GH Automations, and everything's working great.
