Seeking help to migrate these drivers/apps from ST
I've got 1/2/3 gang switches from 3A Smarthome (Products) and I'm looking for some help to port the apps/drivers from ST - anyone achieved this or perhaps anyone up for a paid gig?
Smartthings implementation:
1 Gang DH https://pastebin.com/mYQcxMML
2 Gang DH https://pastebin.com/QpeCFUUA
3 Gang DH https://pastebin.com/d1ayFf9j
1 Gang Smart App - Not Required - Does not need virtual Switches
2 Gang Smart App https://pastebin.com/V18E93ni
3 Gang Smart App https://pastebin.com/Pj51hUas
The app for 3 gang installed with one mod adding a name in namespace: "", example "vjv" in line 11
The driver(DH)for 3 gang installed with a mod on line 157, change physicalgraph to hubitat
Then install and test to see if you get it working.
Edit, Easier, here is the 3 gang app modified
 *  HUI Wall Switch Binder original from Andy's SmartApp - shamlessly borrowed by the netsheriff and modded.
 *  This app allows you to bind 3 Virtual On/Off Tiles to the 3 switchable outlets.
 *  Author: simic with mod by netsheriff
 *  Date: 05/09/2017
// Automatically generated. Make future change here.
definition(
    name: "HUI Wall Switch Binder 1.1 for 3 Gang Switch",
    namespace: "you",
    author: "netsheriff",
    description: "This app allows you to bind 3 Virtual On/Off Tiles to the 3 switchable outlets.",
    category: "Convenience",
    iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
    iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience%402x.png")
preferences {
	section("Which HUI Wall Switch is used?"){
		input "strip", "capability.Switch"
	section("Select a Virtual Switch to bind to Outlet 1"){
		input "switch1", "capability.Switch"
    section("Select a Virtual Switch to bind to Outlet 2"){
		input "switch2", "capability.Switch"
    section("Select a Virtual Switch to bind to Outlet 3"){
		input "switch3", "capability.Switch"
def installed() {
	log.debug "Installed with settings: ${settings}"
    subscribe(strip, "switch.on", MainSwitchOnOneHandler)
    subscribe(strip, "switch.off", MainSwitchOffOneHandler)
    subscribe(strip, "switch1.on", MainSwitchOnOneHandler)
    subscribe(strip, "switch1.off", MainSwitchOffOneHandler)
    subscribe(strip, "switch2.on", MainSwitchOnTwoHandler)
    subscribe(strip, "switch2.off", MainSwitchOffTwoHandler)
    subscribe(strip, "switch3.on", MainSwitchOnThreeHandler)
    subscribe(strip, "switch3.off", MainSwitchOffThreeHandler)
	subscribe(switch1, "switch.on", switchOnOneHandler)
    subscribe(switch2, "switch.on", switchOnTwoHandler)
    subscribe(switch3, "switch.on", switchOnThreeHandler)
    subscribe(switch1, "switch.off", switchOffOneHandler)
    subscribe(switch2, "switch.off", switchOffTwoHandler)
    subscribe(switch3, "switch.off", switchOffThreeHandler)
def updated(settings) {
	log.debug "Updated with settings: ${settings}"
	unsubscribe()
def MainSwitchOnOneHandler(evt) {
	log.debug "switch on"
	switch1.on()
def MainSwitchOffOneHandler(evt) {
	log.debug "switch off"
	switch1.off()
def MainSwitchOnTwoHandler(evt) {
	switch2.on()
def MainSwitchOffTwoHandler(evt) {
	switch2.off()
def MainSwitchOnThreeHandler(evt) {
	switch3.on()
def MainSwitchOffThreeHandler(evt) {
	switch3.off()
def switchOnOneHandler(evt) {
	log.debug "switch on1"
	strip.on()
def switchOnTwoHandler(evt) {
	log.debug "switch on2"
	strip.on2()
def switchOnThreeHandler(evt) {
	log.debug "switch on3"
	strip.on3()
def switchOffOneHandler(evt) {
	log.debug "switch off1"
	strip.off()
def switchOffTwoHandler(evt) {
	log.debug "switch off2"
	strip.off2()
def switchOffThreeHandler(evt) {
	log.debug "switch off3"
	strip.off3()
Here is the driver fror 3 gang modified
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 *  Based on on original by Lazcad / RaveTam
 *  Mods for Hui 3 Gang Switch by Netsheriff
metadata {
    definition (name: "HUI ZigBee Wall Switch 3 Gang V.3.0", namespace: "", author: "smartthings") {
        capability "Actuator"
        capability "Configuration"
        capability "Refresh"
        capability "Switch"
        capability "Health Check"
        fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006"
        fingerprint profileId: "0104", inClusters: "0000, 0003, 0006", outClusters: "0003, 0006, 0019, 0406", manufacturer: "Leviton", model: "ZSS-10", deviceJoinName: "Leviton Switch"
        fingerprint profileId: "0104", inClusters: "0000, 0003, 0006", outClusters: "000A", manufacturer: "HAI", model: "65A21-1", deviceJoinName: "Leviton Wireless Load Control Module-30amp"
        fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006", outClusters: "0003, 0006, 0008, 0019, 0406", manufacturer: "Leviton", model: "DL15A", deviceJoinName: "Leviton Lumina RF Plug-In Appliance Module"
        fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006", outClusters: "0003, 0006, 0008, 0019, 0406", manufacturer: "Leviton", model: "DL15S", deviceJoinName: "Leviton Lumina RF Switch"
        attribute "lastCheckin", "string"
        attribute "switch", "string"
        attribute "switch1", "string"
    	attribute "switch2", "string"
        attribute "switch3", "string"
    command "on0"
    command "off0"
    command "on"
    command "off"
    command "on2"
	command "off2"
	command "on3"
	command "off3"
        attribute "switch1","ENUM",["on","off"]
        attribute "switch2","ENUM",["on","off"]
        attribute "switch3","ENUM",["on","off"]
        attribute "switchstate","ENUM",["on","off"]
    // simulator metadata
    simulator {
        // status messages
        status "on": "on/off: 1"
        status "off": "on/off: 0"
        status "switch1 on": "on/off: 1"
		status "switch1 off": "on/off: 0"
        status "switch2 on": "on/off: 1"
		status "switch2 off": "on/off: 0"
		status "switch3 on": "on/off: 1"
		status "switch3 off": "on/off: 0"
        // reply messages
        reply "zcl on-off on": "on/off: 1"
        reply "zcl on-off off": "on/off: 0"
    tiles(scale: 1) {
     multiAttributeTile(name:"switch", type: "device.switch", width: 1, height: 1, canChangeIcon: true){
            tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
                attributeState "on", label:'${name}', action:"off0", icon:"st.switches.light.on", backgroundColor:"#00a0dc", nextState:"turningOff"
                attributeState "off", label:'${name}', action:"on0", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
                attributeState "turningOn", label:'${name}', action:"off0", icon:"st.switches.light.on", backgroundColor:"#00a0dc", nextState:"turningOff"
                attributeState "turningOff", label:'${name}', action:"on0", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
           	tileAttribute("device.lastCheckin", key: "SECONDARY_CONTROL") {
    			attributeState("default", label:'Last Update: ${currentValue}',icon: "st.Health & Wellness.health9")
        multiAttributeTile(name:"switch1", type: "device.switch", width: 1, height: 1, canChangeIcon: true){
            tileAttribute ("device.switch1", key: "PRIMARY_CONTROL") {
                attributeState "on", label:'SW1 On', action:"off", icon:"st.switches.light.on", backgroundColor:"#00a0dc", nextState:"turningOff"
                attributeState "off", label:'SW1 Off', action:"on", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
                attributeState "turningOn", label:'Turning On', action:"off", icon:"st.switches.light.on", backgroundColor:"#00a0dc", nextState:"turningOff"
                attributeState "turningOff", label:'Turning Off', action:"on", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
        multiAttributeTile(name:"switch2", type: "device.switch", width: 1, height: 1, canChangeIcon: true){
            tileAttribute ("device.switch2", key: "PRIMARY_CONTROL") {
                attributeState "on", label:'SW2 On', action:"off2", icon:"st.switches.light.on", backgroundColor:"#00a0dc", nextState:"turningOff"
                attributeState "off", label:'SW2 Off', action:"on2", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
                attributeState "turningOn", label:'Turning On', action:"off2", icon:"st.switches.light.on", backgroundColor:"#00a0dc", nextState:"turningOff"
                attributeState "turningOff", label:'Turning Off', action:"on2", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
	    multiAttributeTile(name:"switch3", type: "device.switch", width: 1, height: 1, canChangeIcon: true){
            tileAttribute ("device.switch3", key: "PRIMARY_CONTROL") {
                attributeState "on", label:'SW3 On', action:"off3", icon:"st.switches.light.on", backgroundColor:"#00a0dc", nextState:"turningOff"
                attributeState "off", label:'SW3 Off', action:"on3", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
                attributeState "turningOn", label:'Turning On', action:"off3", icon:"st.switches.light.on", backgroundColor:"#00a0dc", nextState:"turningOff"
                attributeState "turningOff", label:'Turning Off', action:"on3", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
        standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 1, height: 1) {
            state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
       main(["switch"])
        details(["switch1","switch2","switch3", "refresh"])
// Parse incoming device messages to generate events
   log.debug "Parsing '${description}'"
   def value = zigbee.parse(description)?.text
   log.debug "Parse: $value"
   Map map = [:]
   if (description?.startsWith('catchall:')) {
		map = parseCatchAllMessage(description)
	else if (description?.startsWith('read attr -')) {
		map = parseReportAttributeMessage(description)
    else if (description?.startsWith('on/off: ')){
    log.debug "onoff"
    def refreshCmds = zigbee.readAttribute(0x0006, 0x0000, [destEndpoint: 0x10]) +
    				  zigbee.readAttribute(0x0006, 0x0000, [destEndpoint: 0x11]) +
    				  zigbee.readAttribute(0x0006, 0x0000, [destEndpoint: 0x12])
   return refreshCmds.collect { new hubitat.device.HubAction(it) }
    	//def resultMap = zigbee.getKnownDescription(description)
   		//log.debug "${resultMap}"
        //map = parseCustomMessage(description)
	log.debug "Parse returned $map"
    //  send event for heartbeat
    def now = new Date()
    sendEvent(name: "lastCheckin", value: now)
	def results = map ? createEvent(map) : null
	return results;
private Map parseCatchAllMessage(String description) {
	Map resultMap = [:]
	def cluster = zigbee.parse(description)
	log.debug cluster
    if (cluster.clusterId == 0x0006 && cluster.command == 0x01){
    	if (cluster.sourceEndpoint == 0x10)
        log.debug "Its Switch one"
    	def onoff = cluster.data[-1]
        if (onoff == 1)
        	resultMap = createEvent(name: "switch", value: "on")
        else if (onoff == 0)
            resultMap = createEvent(name: "switch", value: "off")
            else if (cluster.sourceEndpoint == 0x11)
            log.debug "Its Switch two"
        if (onoff == 1)
        	resultMap = createEvent(name: "switch2", value: "on")
            resultMap = createEvent(name: "switch2", value: "off")
	 else if (cluster.sourceEndpoint == 0x12)
            log.debug "Its Switch three"
        if (onoff == 1)
        	resultMap = createEvent(name: "switch3", value: "on")
            resultMap = createEvent(name: "switch3", value: "off")
	return resultMap
def off() {
    log.debug "off()"
	sendEvent(name: "switch1", value: "off")
   	"st cmd 0x${device.deviceNetworkId} 0x10 0x0006 0x0 {}"
def on() {
   log.debug "on()"
	sendEvent(name: "switch1", value: "on")
    "st cmd 0x${device.deviceNetworkId} 0x10 0x0006 0x1 {}"
def off2() {
    log.debug "off2()"
	sendEvent(name: "switch2", value: "off")
    "st cmd 0x${device.deviceNetworkId} 0x11 0x0006 0x0 {}"
def on2() {
   log.debug "on2()"
	sendEvent(name: "switch2", value: "on")
    "st cmd 0x${device.deviceNetworkId} 0x11 0x0006 0x1 {}"
	def off3() {
    log.debug "off3()"
	sendEvent(name: "switch3", value: "off")
    "st cmd 0x${device.deviceNetworkId} 0x12 0x0006 0x0 {}"
def on3() {
   log.debug "on3()"
	sendEvent(name: "switch3", value: "on")
    "st cmd 0x${device.deviceNetworkId} 0x12 0x0006 0x1 {}"
def off0() {
    log.debug "off0()"
	sendEvent(name: "switch", value: "off")
    "st cmd 0x${device.deviceNetworkId} 0xFF 0x0006 0x0 {}"
def on0() {
   log.debug "on0()"
	sendEvent(name: "switch", value: "on")
    "st cmd 0x${device.deviceNetworkId} 0xFF 0x0006 0x1 {}"
def refresh() {
	log.debug "refreshing"
        "st rattr 0x${device.deviceNetworkId} 0x10 0x0006 0x0", "delay 1000",
        "st rattr 0x${device.deviceNetworkId} 0x11 0x0006 0x0", "delay 1000",
    	"st rattr 0x${device.deviceNetworkId} 0x12 0x0006 0x0", "delay 1000",
private Map parseCustomMessage(String description) {
	def result
	if (description?.startsWith('on/off: ')) {
    	if (description == 'on/off: 0')
    		result = createEvent(name: "switch", value: "off")
    	else if (description == 'on/off: 1')
    		result = createEvent(name: "switch", value: "on")
    return result
Device driver installed. When I try to install the App, it asks for me to choose a HUI Wall Switch but there are none in the list, even though i've assigned the driver to the device.
Yes, tested and it's not showing the switches, I'm not a coder, this was only the basic to port a driver, now more help is needed from a coder. Sorry.
Change all of the “capability.Switch” references to “capability.switch”
Yes, that gave me the ability to choose the device. Thank you. Still no joy with turning individual switches on and off though.
Looks like all of the st cmd and st rattr needs to be he cmd and he rattr based off of this post
This was solved for the 3-gang switches in this thread: Australian approved light switches
