Seedan Zigbee Plug
Has anyone been able to pair the Seedan Zigbee Plugs?
https://www.amazon.com/Seedan-Required-Samsung-SmartThings-Hub-Remote/dp/B08LD7Q81J/ref=sr_1_1?crid=L1TYNBMWXUWW&dchild=1&keywords=seedan+zigbee&qid=1615147019&sprefix=Seedan%2Ctools%2C439&sr=8-1
I just bought and am having issues pairing with an H5 hub.
They work fine with the built-in Generic Zigbee Outlet driver (also on a C-5 Hubitat). Here's what the data on the device page looks like:
I meant C5. How did you pair them? I can’t get mine to pair.
The outlet is blinking but when I hit zigbee pair the Hubitat doesn’t find it.
Did you put the outlet into pairing mode?
I used these instructions to put the outlet into pairing mode:
Thank you. The hold the button for 10 seconds did the trick!
I’m paired and the plugs are working.
Do these report power?
No. Unfortunately not.
@aaiyar What would you recommend for a power reporting zigbee plug?
These newer Sengled Zigbee outlets are repeaters (unlike the earlier Sengled outlets), and they report power.
I'd go with @ogiewon's recommendation. I still use Iris V2 plugs for power reporting.
Ordered a couple for Xmas stuff. Figured I'd repurpose them for something else later.
anyone know if these are UL/ETL/other certified?
They are not UL certified. Not sure about ETL or any other certification.
That has not worked for me, I've tried just about everything, the lights after count of 5 turn purple and red yet never pairs with the Hubitat
What do the logs indicate?
Welcome to Hubitat forums!
Like Aaiyar says, open the Logs tab in Hubitat in a new window or new browser tab, and see what happens when you try to pair.
Ah I will do that thanks!
My note from other thread: Not sure what Log files, I did go through the Logs a minute ago, nothing that I could see. I have two of these devices and have been trying both most of the day. Each time I reset by holding count of 10, but most of the response from the device happens at a 5 count. Then as I said it flickers between purple-ish and red until i push the on-off button. I have also reset it then used it with a light plugged in. Once I turn it on with the button then the light goes on and off until i hit the button to stop it.
Ok the log just shows the discovery process starting then stopping after 60 seconds. So it must not be seeing the Seedan
Open logs while pairing. Before pairing, factory reset the switch. Watch logs while pairing
They have done this (they started two threads about it) and the logs show Zigbee in pairing mode, and nothing more.
We suspect they have the Wifi version of the plug instead of Zigbee at this point.
