Security Updates
This is meant for security issues to be discussed.
What is Hubitat's current response for the current PHP2Shell and CA (Emudhra) situation?
@gopher.ny
I don't believe that PHP is loaded on the hub (at all), and I'm certain, that even if it is, it's not exposed via the Jetty WebServer so I there should be no real action required given no external facing (LAN or WAN) instance of PHP exists. (Java and Groovy are certainly other stories). The hub's user sandbox doesn't allow OS/CLI access without lots of extra efforts (aka physical access to the serial console/debug pins on the bottom of the board)
As for the CA issues, that was a CA that issued 8 bad certs, none of which are used by the Hub's default certs (local only), nor the HE AWS infrastructure (that the hub uses for most HE cloud and admin functions). If a person loads a user cert, that was generated from Emudhra chain of trust, it's going to be on them to update it. If some third party cloud function uses a Emudhra cert, again, it will be up to them to revoke/update it. I don't believe the hub's SSL connection libraries are using CRL's so it's not like the hub is going to stop working if external 3rd party clouds have weak certs.
I'm not entirely sure what you expect HE to do here, as I don't see either of these activities/vulnerabilities directly impacting the default HE/stock software on the hub. Heck they just recently got the required TLS updates implemented in one of the recent V2.5 versions.
YMMV, and I welcome any corrections from staff.
The problem with the eMudhra cert issue is the certs that were issued incorrectly are CA Intermediate certs. They are part of the Global CA Chain for trusting issued certs. The bad intermediate certs were issued with such poor crypto they could be easily forged and issue certs to bad actors to use under a trusted chain.
The only real solution is to revoke the problem CA intermediate Certs in the keystore in the hubs if it is present.
Hopefully they are not on the hubs in the first place and nothing needs to happen, but they really should be revoked if they are in the keystore as a trusted CA.
There's no PHP on the hub or in Hubitat cloud infrastructure.
We'll have the firmware update the JRE once there is an updated version.
