Security IP address filtration for dashboard
Hi,
There is probably a way for doing this, but I would like to have one that could be configure in the advance setting for dashboard.
So, I have several dashboards and some of them are for a tablet fixed on a wall. However, I would like for that tablet to not being able to access my other dashboards not made for this device. The reason that I would like to have that is because on my cell phone I don't use the HSM pin but I use it for my tablet. Just a suggestion!
I don't think that's something that can be done in hubitat given the code that would need to be implemented. That said, you could create a vlan and have your rules do that though that will require an intelligent switch and a good routing firewall. I could easily do that in Watchguard or PIX/ASA and I'm sure most other good firewalls do it... You could also maybe use an rpi as a gateway in front of your main router to do it...Natively though, there isn't a way. You could set specific user access to each dashboard.... (yeah I know im rambling)
