Secure vs Non Secure Z-Wave Inclusion
I recently purchased a HomeSeer HS-LS100+ Z-wave lead sensor.
The instructions recommend secure inclusion. I've read that unless needed it was best to include as non-secure.
So I'm not clear on the benefits of "secure" inclusion. Normally I would see "secure" as needed on a door lock, garage door opener etc. But not a leak sensor.
When I google this question I get articles talking about security as is needed for door locks.
Is there something else that results from a link being secure?
John
I have found that you will have less problems with your zwave mesh if you only use secure inclusion on locks/garage doors everything else non-secure.
For a leak sensor there would be zero benefit, so you are correct, and this is bad advice from the manufacturer...
