Second ever Driver http Response broken
Below is my code for the poll
def poll() {
    if (logEnable) log.debug "polling..."
    String url = "http://api.thingspeak.com/channels/1417/field/1/last.txt"
    try {
        httpGet(url) { response ->
            def body = response.data
            if (logEnable) log.debug "${body}"
            sendEvent(name: "color1", value: body, isStateChange: true);
    } catch(Exception e) {
    	log.debug "error occured calling httpget ${e}"
The log looks like this
But the Driver looks like this
I have tried just about everything I have seen in the forums and online. HELP!
Changing the code to the value of of body, yields the following error in the log
Try changing the following line
From
To
def body = new String(response.data)
We need store a copy of the contents in a variable, rather than just a reference to it.
That yields a new error
I also tried response.data.ToString() and got a similar error.
I am not a programmer but it seems that response.data is Schrödinger data... as is both a string and not a string at the same time
Try
def body = new String("${response.data}"}
That worked...thanks a ton. I am so not a programmer. But i am happy to get this hacked together!
Glad it helped. I had literally just figured out the exact same thing last night in an app I was working on. There may be a better solution, but this at least works for now. If others have a better solution, I am all ears. :wink:
Now I just have to get the rest of the code needed to set some bulbs to match the color!
@cheerlights on Twitter!
