Search a variable or file for value in another variable
New to rule machine and I’m trying to figure out if I can evaluate if file or a variable contains the content of another varable (that stores current time hh:mm). I store the time stamp every time when a device is changed in a file(or variable), and then that is used to determain if a device should be turned on. I use it to ā€˜replay’ the the lights in my house when I’m not home.
Any help is greatly would be great, I’ve looked all over for info but can’t find any on this specific case.
Thanks, i just to ask to get to work :slight_smile: I was trying to compare a dateTime var with a string. When changing the dtaeTime to string the compare seem to work
