Migrant from wink over here. I used to have an alert if the door lock was jammed. Will eventually get a contact sensor to detect the door is opened. But is there any way to get a notification if door jams.
I do see under device events it reports unknown when jammed.
You need to create a new condition using the Custom Attribute capability. Select the lock and then you should see lock attribute and the unknown under value.
