I am brand new to Hubitat and I have tried searching for this issue but haven't found an answer yet. I currently have the BE469ZP connected to the Hubitat. For some reason it requires two clicks (not a fast "double click") on the Lock or Unlock icon in order to get the lock to respond. This means that the automation to have the lock automatically set at a certain time doesn't work. Has anyone else seen this issue or know how to fix it? The device settings are below:
deviceType: 1
zwaveSecurePairingComplete: true
inClusters: 0x5E,0x98,0x9F,0x55,0x6C,0x8A,0x22
zwNodeInfo: 53 DC 04 04 40 03 5E 98 9F 55 6C 8A 22 68 23 F1 00 5D 85 5C 70 80 62 71 63 4E 8A 6C 72 86 7A 22 59 5A 73 87
I'm using reliable locks, and my be469ZP still sucks. My older BE469Z(non-plus) was 100 times more reliable even without reliable locks. I have 2 repeaters in the same room, Aeotec 7 & Ring Extender, both beaming repeaters.
I upgraded the board from z-wave to z-wave plus and I'm considering going back to non-plus
Ditto. I have replaced my new be469ZP twice. Still the same problem. At least Reliable Locks works, most of the time. Does changing the security from default (presented at inclusion) help at all?
I've been using it for the past two days now and it has been reliable so far. I know that is a short testing period and it may help that the hub is about 10 ft away from the lock. Hopefully it will continue working. Now I just need to figure out how to get my Yale locks to connect!
It could just be the driver. I suspect it hasn't been updated since the ZP/S2 locks came out (I have heard they dropped them off the compatibility list some time ago). So, it might be less than ideal in some cases?? @bcopeland has been doing some really great stuff with the S2 protocols but that isn't likely reflected with these drivers.
