I have 4 of these locks. 2 of them are directly within 5-10 ft from my hubitat hub, along with an aeotech range extender close-by, 2 locks are are farther away, also near aeotech range extenders. The two closest to the hubitat hub consistently stop working. I have removed them, reset them, re-added them, and put them back into my automations (via Swap Apps) and they only work for a bit. I reached out to Schlage about my issues, and this was their response:
Thank you for contacting Schlage Support. I am sorry to hear you are having issues with your lock and your Z-wave hub. The best advised we have is to exclude and include within 5ft of the hub.
However, this process still might not resolve your issue. Due to a recent update with the habitat hub, Schlage is no longer a partner for their operating system. So, your issue comes down to the compatibility of the hub you are using. We would recommend contacting Hubitat to see if they have a work around as your hub was previously paired.
I followed back up with them that they are within 5 feet of the hub, they successfully pair, but then stop working shortly thereafter. They responded with this:
Thank you for replying to Schlage Support. You are correct that our older Connect locks often could pair with the Hubitat hub. When they did an update to their hub, Schlage locks are not always operable with their system. Which is why we have removed them from our Z-wave partners and are no longer on their compatible device list. Please see the link below.
List of Compatible Devices | Hubitat Documentation
Schlage smart locks works with Voice assistants, Home automation, Security
We have also updated our locks to the new Z-wave Plus function. Our Z-wave plus firmware is known not to pair to the Hubitat hub. This is why we are referring you to Hubitat as a replacement lock will not resolve your issue.
After you have communicated with Hubitat, can you let us know their resolution? You can reply to this email or call us at 888-805-9837 referencing your case number, xxxxx, and anyone would be happy to help.
So they are now saying that their updated Z-wave Plus locks will NOT work with Hubitat. What does Hubitat have to say about this? I was hoping they would swap my locks for ones that would work. My next plan is to move everything from my primary hubitat hub (C5 with a external stick from my C4) to a C7. I have tried pairing the existing locks with the C7 and they appear to be more responsive (of course there is nothing else on that hub).
