Hi, I am working to migrate my devices from ST to Hubitat step by step, now I want to migrate my 2 Schlage BE469, I have the Rboy App on ST what is the option similar on Hubitat?
Use the generic zwave lock handler in conjunction with the recently released lock code manager. One thing to keep in mind, you will need to delete all codes on the lock and then add them back through Hubitat. Hubitat cannot read currently saved codes as that is a limitation of the Schlage locks.
Let me know if you have any questions, I have the same locks and am using them with no issues.
You may want to just move one lock and decide if Lock Code Manager is enough for you right now. I've never used Rboy, but from the descriptions, it's a lot more capable than Lock Code Manager is at this stage.
Here's the doc for Lock Code Manager so you can take a look before you make that change.
