I have a couple of scenes. I see in the logs that they are throwing a Java exception every minute. The string in question is the level in the Lifx bulb in the scene. Any thoughts/ideas/fixes? Is this a straight up bug in the Scene code, the Lifx code or ?? Logs entry samples follow: app:10122021-05-06 10:37:04.205 am errorjava.lang.NumberFormatException: For input string: "87.37" on line 627 (checkScene)
[app:1014](http://192.168.4.136/logs#pastapp1014)2021-05-06 10:37:04.200 am [error](http://192.168.4.136/installedapp/configure/1014)java.lang.NumberFormatException: For input string: "87.37" on line 627 (checkScene)
[app:1012](http://192.168.4.136/logs#pastapp1012)2021-05-06 10:36:04.248 am [error](http://192.168.4.136/installedapp/configure/1012)java.lang.NumberFormatException: For input string: "87.39" on line 627 (checkScene)
[app:1014](http://192.168.4.136/logs#pastapp1014)2021-05-06 10:36:04.245 am [error](http://192.168.4.136/installedapp/configure/1014)java.lang.NumberFormatException: For input string: "87.39" on line 627 (checkScene)
[app:1012](http://192.168.4.136/logs#pastapp1012)2021-05-06 10:35:04.234 am [error](http://192.168.4.136/installedapp/configure/1012)java.lang.NumberFormatException: For input string: "87.4" on line 627 (checkScene)
[app:1014](http://192.168.4.136/logs#pastapp1014)2021-05-06 10:35:04.207 am [error](http://192.168.4.136/installedapp/configure/1014)java.lang.NumberFormatException: For input string: "87.4" on line 627 (checkScene)
[app:1012](http://192.168.4.136/logs#pastapp1012)2021-05-06 10:34:04.215 am [error](http://192.168.4.136/installedapp/configure/1012)java.lang.NumberFormatException: For input string: "87.42" on line 627 (checkScene)
[app:1014](http://192.168.4.136/logs#pastapp1014)2021-05-06 10:34:04.195 am [error](http://192.168.4.136/installedapp/configure/1014)java.lang.NumberFormatException: For input string: "87.42" on line 627 (checkScene)
I still maintain that Hubitat should document preferred/allowed/prescribed attribute types more thoroughly. The only documentation I know of says "NUMBER" is valid for attributes. The "NUMBER" variable type includes decimals.
I am not arguing that having decimals in a "level" or "humidity", etc, attribute are useful - I don't think they are - but I don't think the system should throw an error on a valid data type either.
So the problem is that I have no control over that. I have the level set to 30 (or 60) and then capture the scene. Somehow it gets automagically converted to a float in the guts somewhere.
I really wish I could get the integer to stick. I kind of guessed this was the problem (was a Sun Certified Have Developer some 20 years ago...) but don't see how I would change it.
But what is the level on the actual lights? If the scene is reading the current level from the lights, and there is a decimal there, that could throw the error too (maybe - no idea what is on line 627 of the scene app code).
Good point. So, the problem is that in adjust scene they look like integers (shows 60). When I go into the device itself. Even when I enter an int it looks like a float. I think this is a LIFX driver issue.
That is my GUESS as well. I don't have any LIFX bulbs to test it against though.
That said, I think the scenes app should handle it more gracefully anyway. Similar to the changes Bruce recently put in the Simple Automation Rules app to handle getting floats when integers were expected.
Agree. The point of throwing exceptions in Java is that the code can catch them and do something smart when the condition happens. Your code fragment is what they should have done. For now, I'm removing these scenes and hard coding the behavior in a rule.
My only point is that we can't really blame developers for doing something that isn't documented... The only documentation I know of says NUMBER is a valid attribute variable type, and NUMBER includes floats.
