Generic ZigBee RGBW Light
Copyright 2016 -> 2020 Hubitat Inc. All Rights Reserved
2019-12-20 2.1.8 maxwell
-add Nue HGZB-18A
-add RGBGenie ZB-1025
2019-11-14 2.1.7 maxwell
-add GLEDOPTO Mini Zigbee RGB+CCT Controller
-add Nue HGZB-07A
-add Innr GU10 Colour bulb
2019-09-02 2.1.5 maxwell
-add white as a color
-change bindings to advertised endpoint
2019-05-28 2.1.1 maxwell
-fp update
2019-01-05 2.0.5 maxwell
-fp update
2018-12-05 2.0.2 maxwell
-fp update
2018-10-12 ravenel
-add rate to setColor
2018-06-04 maxwell
-updates to support changeLevel
-add capability color mode
2018-04-09 maxwell
-add transition and color staging options
2018-03-24 maxwell
-patch NPE on config log settings
metadata {
definition (name: "Altered Generic ZigBee RGB", namespace: "hubitat", author: "Mike Maxwell") {
capability "Actuator"
capability "Color Control"
capability "Color Temperature"
capability "Configuration"
capability "Refresh"
capability "Switch"
capability "Switch Level"
capability "ChangeLevel"
capability "Light"
capability "ColorMode"
// fingerprint profileId: "0104", inClusters: "0000,0003,0004,0005,0006,0008,0300,0B04,FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "LIGHTIFY Flex RGBW", deviceJoinName: "SYLVANIA Smart Flex RGBW"
// fingerprint profileId: "0104", inClusters: "0000,0003,0004,0005,0006,0008,0300,0B04,FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "Flex RGBW", deviceJoinName: "OSRAM LIGHTIFY Flex RGBW"
// fingerprint profileId: "0104", inClusters: "0000,0003,0004,0005,0006,0008,0300,FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "LIGHTIFY A19 RGBW", deviceJoinName: "SYLVANIA Smart A19 RGBW"
// fingerprint profileId: "0104", inClusters: "0000,0003,0004,0005,0006,0008,0300,0B04,FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "LIGHTIFY BR RGBW", deviceJoinName: "SYLVANIA Smart BR30 RGBW"
// fingerprint profileId: "0104", inClusters: "0000,0003,0004,0005,0006,0008,0300,0B04,FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "LIGHTIFY RT RGBW", deviceJoinName: "SYLVANIA Smart RT5/6 RGBW"
// fingerprint profileId: "0104", inClusters: "0000,0003,0004,0005,0006,0008,0300,0B04,FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "LIGHTIFY FLEX OUTDOOR RGBW", deviceJoinName: "SYLVANIA Smart Outdoor RGBW Flex"
// fingerprint profileId: "C05E", inClusters: "0000,0003,0004,0005,0006,0008,0300,1000", outClusters: "0019", manufacturer: "Philips", model: "LCT001", deviceJoinName: "Philips Hue Lux Bulb"
// fingerprint profileId: "C05E", inClusters: "0000,0003,0004,0005,0006,0008,0300,1000,FC01", outClusters: "0019", manufacturer: "Philips", model: "LCT001", deviceJoinName: "Philips Hue Lux Bulb"
// fingerprint profileId: "C05E", inClusters: "1000,0000,0003,0004,0005,0006,0008,0300,FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "CLA60 RGBW OSRAM", deviceJoinName: "OSRAM Classic E27 Multicolor"
// fingerprint profileId: "C05E", inClusters: "0000,0003,0004,0005,0006,0008,0300,1000", outClusters: "0019", manufacturer: "Philips", model: "LST002", deviceJoinName: "Philips Hue White and Color Ambiance LightStrip"
// fingerprint profileId: "C05E", inClusters: "0000,0003,0004,0005,0006,0008,1000,0300", outClusters: "0019", manufacturer: "Philips", model: "LST002", deviceJoinName: "Philips Hue White and Color Ambiance LightStrip"
// fingerprint profileId: "0104", inClusters: "0000,0003,0004,0005,0006,0008,0300,0B05,FC01", outClusters: "0019", manufacturer: "LEDVANCE", model: "BR30 RGBW", deviceJoinName: "SYLVANIA Smart + RGBW"
// fingerprint profileId: "0104", inClusters: "0000,0003,0004,0005,0006,0008,0300,0B05,FC03", outClusters: "0019", manufacturer: "sengled", model: "E1G-G8E", deviceJoinName: "Sengled RGBW LED Strip"
// fingerprint profileId: "0104", inClusters: "0000,0003,0004,0005,0006,0008,0300,0B05,FC01", outClusters: "0019", manufacturer: "LEDVANCE", model: "A19 RGBW", deviceJoinName: "SYLVANIA Smart + RGBW"
fingerprint profileId:"C05E", endpointId:"0A", inClusters:"0000,1000,0003,0004,0005,0006,0008,0300,FCCE", outClusters:"0019", model:"FLS-PP Color", manufacturer:"Dresden", deviceJoinName: "FLS-PP Color"
fingerprint profileId:"C05E", endpointId:"0B", inClusters:"0000,1000,0003,0004,0005,0006,0008", outClusters:"0019", model:"FLS-PP White", manufacturer:"Dresden", deviceJoinName: "FLS-PP White"
// fingerprint profileId: "0104", inClusters: "0000,0003,0004,0005,0006,0008,0300,0B05,1000,FC82", outClusters: "0019", manufacturer: "innr", model: "RS 230 C", deviceJoinName: "Innr GU10 Colour bulb"
// fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0004,0003,0006,0008,0005,0300,1000,0019", outClusters:"0019", model:"LXT56-LS27LX1.4", manufacturer:"3A Smart Home DE", deviceJoinName: "Nue HGZB-18A strip controller"
// fingerprint profileId:"C05E", endpointId:"01", inClusters:"0000,0003,0004,0005,0006,0008,0300,0B05,1000", outClusters:"0019,1000", model:"RGBgenie ZB-1025", manufacturer:"RGBgenie", deviceJoinName: "RGBGenie ZB-1025 strip controller"
preferences {
input name: "transitionTime", type: "enum", description: "", title: "Transition time", options: [[500:"500ms"],[1000:"1s"],[1500:"1.5s"],[2000:"2s"],[5000:"5s"]], defaultValue: 1000
input name: "colorStaging", type: "bool", description: "", title: "Enable color pre-staging", defaultValue: false
input name: "hiRezHue", type: "bool", title: "Enable Hue in degrees (0-360)", defaultValue: false
input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
input name: "txtEnable", type: "bool", title: "Enable descriptionText logging", defaultValue: true
def logsOff(){
log.warn "debug logging disabled..."
device.updateSetting("logEnable",[value:"false",type:"bool"])
def updated(){
log.info "updated..."
log.warn "Hue in degrees is: ${hiRezHue == true}"
log.warn "debug logging is: ${logEnable == true}"
log.warn "description logging is: ${txtEnable == true}"
if (logEnable) runIn(1800,logsOff)
if (logEnable) log.debug "parse description: ${description}"
if (description.startsWith("catchall")) return
def descMap = zigbee.parseDescriptionAsMap(description)
def descriptionText
def rawValue = Integer.parseInt(descMap.value,16)
def value
def name
def unit
switch (descMap.clusterInt){
case 6: //switch
if (descMap.attrInt == 0){
value = rawValue == 1 ? "on" : "off"
name = "switch"
if (device.currentValue("${name}") && value == device.currentValue("${name}")){
descriptionText = "${device.displayName} is ${value}"
} else {
descriptionText = "${device.displayName} was turned ${value}"
} else {
log.debug "0x0006:${descMap.attrId}:${rawValue}"
break
case 8: //level
unit = "%"
value = Math.round(rawValue / 2.55)
name = "level"
if (device.currentValue("${name}") && value == device.currentValue("${name}").toInteger()){
descriptionText = "${device.displayName} is ${value}${unit}"
} else {
descriptionText = "${device.displayName} was set to ${value}${unit}"
} else {
log.debug "0x0008:${descMap.attrId}:${rawValue}"
break
case 0x300: //color
switch (descMap.attrInt){
case 0: //hue
if (hiRezHue){
//hue is 0..360, value is 0..254 Hue = CurrentHue x 360 / 254
value = Math.round(rawValue * 360 / 254)
if (value == 361) value = 360
unit = "°"
} else {
value = Math.round(rawValue / 254 * 100)
unit = "%"
name = "hue"
descriptionText = "${device.displayName} ${name} is ${value}${unit}"
} else {
descriptionText = "${device.displayName} ${name} was set to ${value}${unit}"
state.lastHue = descMap.value
break
case 1: //sat
name = "saturation"
unit = "%"
} else {
state.lastSaturation = descMap.value
break
case 7: //ct
value = (1000000 / rawValue).toInteger()
name = "colorTemperature"
unit = "°K"
} else {
state.lastCT = descMap.value
break
case 8: //cm
if (rawValue == 2) { //ColorTemperature
setGenericTempName(device.currentValue("colorTemperature"))
} else if (rawValue == 0){ //HSV
setGenericName(device.currentValue("hue"))
value = rawValue == 2 ? "CT" : "RGB"
name = "colorMode"
descriptionText = "${device.displayName} ${name} is ${value}"
break
break
if (logEnable) log.debug "evt- rawValue:${rawValue}, value: ${value}, descT: ${descriptionText}"
if (descriptionText){
if (txtEnable) log.info "${descriptionText}"
sendEvent(name:name,value:value,descriptionText:descriptionText, unit: unit)
def startLevelChange(direction){
def upDown = direction == "down" ? 1 : 0
def unitsPerSecond = 100
return "he cmd 0x${device.deviceNetworkId} 0x0A 0x0008 1 { 0x${intTo8bitUnsignedHex(upDown)} 0x${intTo16bitUnsignedHex(unitsPerSecond)} }"
def stopLevelChange(){
return [
"he cmd 0x${device.deviceNetworkId} 0x0A 0x0008 3 {}}","delay 200",
"he rattr 0x${device.deviceNetworkId} 0x0A 0x0008 0 {}"
def on() {
def cmd = [
"he cmd 0x${device.deviceNetworkId} 0x0A 0x0006 1 {}",
"delay 1000",
"he rattr 0x${device.deviceNetworkId} 0x0A 0x0006 0 {}"
return cmd
def off() {
def cmd = [
"he cmd 0x${device.deviceNetworkId} 0x0A 0x0006 0 {}",
"delay 1000",
return cmd
def refresh() {
if (logEnable) log.debug "refresh"
return [
"he rattr 0x${device.deviceNetworkId} 0x0A 0x0006 0 {}","delay 200", //light state
"he rattr 0x${device.deviceNetworkId} 0x0A 0x0008 0 {}","delay 200", //light level
"he rattr 0x${device.deviceNetworkId} 0x0A 0x0300 0x0000 {}","delay 200", //hue
"he rattr 0x${device.deviceNetworkId} 0x0A 0x0300 0x0001 {}","delay 200", //sat
"he rattr 0x${device.deviceNetworkId} 0x0A 0x0300 0x0007 {}","delay 200", //color temp
"he rattr 0x${device.deviceNetworkId} 0x0A 0x0300 0x0008 {}" //color mode
def configure() {
log.warn "configure..."
runIn(1800,logsOff)
def cmds = [
//bindings
"zdo bind 0x${device.deviceNetworkId} 0x0A 0x01 0x0006 {${device.zigbeeId}} {}", "delay 200",
"zdo bind 0x${device.deviceNetworkId} 0x0A 0x01 0x0008 {${device.zigbeeId}} {}", "delay 200",
"zdo bind 0x${device.deviceNetworkId} 0x0A 0x01 0x0300 {${device.zigbeeId}} {}", "delay 200",
//reporting
"he cr 0x${device.deviceNetworkId} 0x0A 0x0006 0 0x10 0 0xFFFF {}","delay 200",
"he cr 0x${device.deviceNetworkId} 0x0A 0x0008 0 0x20 0 0xFFFF {}", "delay 200",
"he cr 0x${device.deviceNetworkId} 0x0A 0x0300 0 0x0000 0 0xFFFF {}", "delay 200",
"he cr 0x${device.deviceNetworkId} 0x0A 0x0300 0 0x0001 0 0xFFFF {}", "delay 200",
"he cr 0x${device.deviceNetworkId} 0x0A 0x0300 0 0x0007 0 0xFFFF {}", "delay 200",
"he cr 0x${device.deviceNetworkId} 0x0A 0x0300 0 0x0008 1 0xFFFE {}", "delay 200",
] + refresh()
return cmds
def setGenericTempName(temp){
if (!temp) return
def genericName
def value = temp.toInteger()
if (value <= 2000) genericName = "Sodium"
else if (value <= 2100) genericName = "Starlight"
else if (value < 2400) genericName = "Sunrise"
else if (value < 2800) genericName = "Incandescent"
else if (value < 3300) genericName = "Soft White"
else if (value < 3500) genericName = "Warm White"
else if (value < 4150) genericName = "Moonlight"
else if (value <= 5000) genericName = "Horizon"
else if (value < 5500) genericName = "Daylight"
else if (value < 6000) genericName = "Electronic"
else if (value <= 6500) genericName = "Skylight"
else if (value < 20000) genericName = "Polar"
def descriptionText = "${device.getDisplayName()} color is ${genericName}"
sendEvent(name: "colorName", value: genericName ,descriptionText: descriptionText)
def setGenericName(hue){
def colorName
hue = hue.toInteger()
if (!hiRezHue) hue = (hue * 3.6)
switch (hue.toInteger()){
case 0..15: colorName = "Red"
break
case 16..45: colorName = "Orange"
break
case 46..75: colorName = "Yellow"
break
case 76..105: colorName = "Chartreuse"
break
case 106..135: colorName = "Green"
break
case 136..165: colorName = "Spring"
break
case 166..195: colorName = "Cyan"
break
case 196..225: colorName = "Azure"
break
case 226..255: colorName = "Blue"
break
case 256..285: colorName = "Violet"
break
case 286..315: colorName = "Magenta"
break
case 316..345: colorName = "Rose"
break
case 346..360: colorName = "Red"
break
if (device.currentValue("saturation") == 0) colorName = "White"
def descriptionText = "${device.getDisplayName()} color is ${colorName}"
sendEvent(name: "colorName", value: colorName ,descriptionText: descriptionText)
def setLevel(value) {
setLevel(value,(transitionTime?.toBigDecimal() ?: 1000) / 1000)
def setLevel(value,rate) {
rate = rate.toBigDecimal()
def scaledRate = (rate * 10).toInteger()
def cmd =
def isOn = device.currentValue("switch") == "on"
value = (value.toInteger() * 2.55).toInteger()
if (isOn){
cmd = [
"he cmd 0x${device.deviceNetworkId} 0x0A 0x0008 4 {0x${intTo8bitUnsignedHex(value)} 0x${intTo16bitUnsignedHex(scaledRate)}}",
"delay ${(rate * 1000) + 400}",
} else {
cmd = [
"he cmd 0x${device.deviceNetworkId} 0x0A 0x0008 4 {0x${intTo8bitUnsignedHex(value)} 0x0100}", "delay 200",
"he rattr 0x${device.deviceNetworkId} 0x0A 0x0006 0 {}", "delay 200",
return cmd
def setColor(value){
if (value.hue == null || value.saturation == null) return
def rate = value?.rate ? value.rate * 1000 : (transitionTime?.toInteger() ?: 1000)
def hexSat = zigbee.convertToHexString(Math.round(value.saturation.toInteger() * 254 / 100).toInteger(),2)
def level
if (value.level) level = (value.level.toInteger() * 2.55).toInteger()
def cmd = []
def hexHue
if (hiRezHue){
hexHue = zigbee.convertToHexString(Math.round(value.hue / 360 * 254).toInteger(),2)
} else {
hexHue = zigbee.convertToHexString(Math.round(value.hue * 254 / 100).toInteger(),2)
if (isOn){
if (value.level){
cmd = [
"he cmd 0x${device.deviceNetworkId} 0x0A 0x0300 0x06 {${hexHue} ${hexSat} ${intTo16bitUnsignedHex(rate / 100)}}","delay 200",
"he cmd 0x${device.deviceNetworkId} 0x0A 0x0008 4 {0x${intTo8bitUnsignedHex(level)} 0x${intTo16bitUnsignedHex(rate / 100)}}",
"delay ${rate + 400}",
"he rattr 0x${device.deviceNetworkId} 0x0A 0x0300 0x0000 {}", "delay 200",
"he rattr 0x${device.deviceNetworkId} 0x0A 0x0300 0x0001 {}", "delay 200",
"he rattr 0x${device.deviceNetworkId} 0x0A 0x0008 0 {}", "delay 200",
} else {
cmd = [
} else if (colorStaging){
cmd = [
"he cmd 0x${device.deviceNetworkId} 0x0A 0x0300 0x06 {${hexHue} ${hexSat} 0x0100}", "delay 200",
} else if (level){
cmd = [
"he cmd 0x${device.deviceNetworkId} 0x0A 0x0008 4 {0x${intTo8bitUnsignedHex(level)} 0x0100}", "delay 200",
} else {
cmd = [
"he cmd 0x${device.deviceNetworkId} 0x0A 0x0006 1 {}","delay 200",
state.lastSaturation = hexSat
state.lastHue = hexHue
return cmd
def setHue(value) {
def hexHue
def rate = transitionTime?.toInteger() ?: 1000
if (hiRezHue){
hexHue = zigbee.convertToHexString(Math.round(value / 360 * 254).toInteger(),2)
} else {
hexHue = zigbee.convertToHexString(Math.round(value * 254 / 100).toInteger(),2)
def hexSat = state.lastSaturation
def cmd =
if (isOn){
cmd = [
cmd = [
} else {
cmd = [
return cmd
def setSaturation(value) {
//saturation is 0.. 100, value is 0..254 Saturation = CurrentSaturation/254
def cmd =
def hexSat = zigbee.convertToHexString(Math.round(value * 254 / 100).toInteger(),2)
def hexHue = state.lastHue
if (isOn){
cmd = [
cmd = [
} else {
cmd = [
return cmd
def setColorTemperature(rawValue) {
def value = intTo16bitUnsignedHex((1000000/rawValue).toInteger())
def cmd =
if (isOn){
cmd = [
"he cmd 0x${device.deviceNetworkId} 0x0A 0x0300 0x000A {${value} ${intTo16bitUnsignedHex(rate / 100)}}",
"he rattr 0x${device.deviceNetworkId} 0x0A 0x0300 0x0007 {}", "delay 200",
cmd = [
"he cmd 0x${device.deviceNetworkId} 0x0A 0x0300 0x000A {${value} 0x0100}", "delay 200",
} else {
cmd = [
state.lastCT = value
return cmd
def installed() {
def intTo16bitUnsignedHex(value) {
def hexStr = zigbee.convertToHexString(value.toInteger(),4)
return new String(hexStr.substring(2, 4) + hexStr.substring(0, 2))
def intTo8bitUnsignedHex(value) {
return zigbee.convertToHexString(value.toInteger(), 2)
