Hi team………… need some advice. I have one of those chandelier that has two sets of LEDs on it, white and yellow which allows you to set the tone of the room. There are 4 different combinations that can be set simply by toggling the switch on and off in 1 second intervals to cycle through the sequences until you get the desired tone you want. I am running a C7 with voice control through an Echo…… how can I automate this using an inovelli red series on/off switch and the echo?
