I've added some new switches to my setup and its been awhile since i've edited a scene but the behavior is not quite what i was expecting.
What is the behavior supposed to be between "Captured Scene" list of values and the "Adjust Scene Settings"?
I was assuming it was the captured value then the adjust would override. But what i seem to observe for me when i hit active scene, is it is always the captured values and the adjustments are ignored. To add a device into the scene, i need to set with the required settings, remove it from the scene, then re-add it back to the scene so it comes in with the appropriate captured value.
You would have to show the scene screenshot, and perhaps the adjust page screenshot. There is a reported bug in Adjust with respect to switch on/off settings (fixed in next release). Did you hit Done on the Adjust Scene page?
Have created a scene and trying to use Adjust Scene to change one of the Dimmers in the scene to Off. I open the Scene, go to Adjust Scene, set the Dimmer to Off, hit Done, Done.
Upon testing the Scene nothing has changed. Maybe I don't understand how the Adjust Scene works.
Has this bug been fixed,
just i added a new device to a scene (ticked the box), went down to adjust, adjusteded it to off, click done . how ever when ran the scene it switch on.
went back into the scene thinking id must have to tick it - save it, edit it the adjust but still not working.
Only sucess i has was to set everying and caputre the scene.
Im on latest firmware (updated last week)
