So, I have a simple 'alarm' piston for my 'garden office' that I'm trying to improve, but it's giving a strange output when it runs twice in a short period of time.
When it is initially triggered by the first event (either a door opening or a motion sensor detection) - I get a message naming the matching device. When another sensor then detects further movement, or a different door opens, I get a message with 'EMPTY DEVICE LIST' vs the expected triggering device.
Logs below.
Suggestions? Thanks in advance.
logs
6/18/2024, 2:49:19 PM +907ms
+3ms ╔Received event [New Front Door].contact = open with a delay of 27ms, canQueue: true, calledMyself: false
+110ms ║Runtime (8682 bytes) initialized 107 LockT > 0ms > r9T > 1ms > pistonT > 0ms (first state access 101 m:5 4 103) (v0.3.114.20240115_HE)
+112ms ║╔Execution stage started
+118ms ║║Comparison (enum) :db51cd17b1529242205547665623a183: is (string) :db51cd17b1529242205547665623a183: = true (2ms)
+119ms ║║Condition #4 evaluated true (4ms)
+121ms ║║Condition group #1 evaluated true (condition did not change) (6ms)
+130ms ║║Comparison (enum) open changes_to (string) open = true (0ms)
+131ms ║║Comparison changes_to = false (event device/attr eXcluded)
+135ms ║║Condition #2 evaluated true (13ms)
+146ms ║║Comparison changes_to = false (event device/attr eXcluded)
+147ms ║║Comparison changes_to = false (event device/attr eXcluded)
+151ms ║║Condition #3 evaluated false (16ms)
+153ms ║║Condition group #1 evaluated true (condition did not change) (31ms)
+163ms ║║Calculating (string)Ahem. My apologies for disturbing you. The alarm has been triggered by the + (string)Empty device list >> (string)Ahem. My apologies for disturbing you. The alarm has been triggered by the Empty device list
+166ms ║║Executed virtual command executePiston (7ms)
+173ms ║║Calculating (string)Empty device list + (string) at >> (string)Empty device list at
+175ms ║║Calculating (string)Empty device list at + (string)14:49 >> (string)Empty device list at 14:49
+179ms ║║Empty device list at 14:49
+182ms ║║Executed virtual command log (3ms)
+189ms ║╚Execution stage complete. (77ms)
+195ms ╚Event processed successfully (192ms)
6/18/2024, 2:49:00 PM +719ms
+3ms ╔Received event [Office Motion].motion/physical = active with a delay of 34ms, canQueue: true, calledMyself: false
+24ms ║Runtime (8568 bytes) initialized 19 LockT > 1ms > r9T > 2ms > pistonT > 0ms (first state access 13 m:3 4 15) (v0.3.114.20240115_HE)
+26ms ║╔Execution stage started
+34ms ║║Comparison (enum) :db51cd17b1529242205547665623a183: is (string) :db51cd17b1529242205547665623a183: = true (2ms)
+35ms ║║Condition #4 evaluated true (5ms)
+37ms ║║Condition group #1 evaluated true (condition changed) (7ms)
+43ms ║║Comparison changes_to = false (event device/attr eXcluded)
+44ms ║║Comparison changes_to = false (event device/attr eXcluded)
+47ms ║║Condition #2 evaluated false (8ms)
+52ms ║║Comparison changes_to = false (event device/attr eXcluded)
+54ms ║║Comparison (enum) active changes_to (string) active = true (0ms)
+58ms ║║Condition #3 evaluated true (10ms)
+59ms ║║Condition group #1 evaluated true (condition did not change) (21ms)
+69ms ║║Calculating (string)Ahem. My apologies for disturbing you. The alarm has been triggered by the + (string)Office Motion >> (string)Ahem. My apologies for disturbing you. The alarm has been triggered by the Office Motion
+73ms ║║Executed virtual command executePiston (8ms)
+80ms ║║Calculating (string)Office Motion + (string) at >> (string)Office Motion at
+82ms ║║Calculating (string)Office Motion at + (string)14:49 >> (string)Office Motion at 14:49
+86ms ║║Office Motion at 14:49
+90ms ║║Executed virtual command log (3ms)
+97ms ║╚Execution stage complete. (71ms)
+104ms ╚Event processed successfully (101ms)
