So decided to continue the issue from my previous jdbc error thread just for fun...
Am in the process of migrating my hubs from 2 C-4s over to a C-7. Have taken great care to build a good infrastructure using a bunch of different repeaters around the house. Have a mixed environment of ZW+ & ZW+ (S2) devices - no ZW. Aside from the usual pairing glitches etc the transition has been fairly straightforward.
This morning 2 of my switches - "Front Lamp Post Light" (Zen23 V4 - fw:4.0) and "Side Porch Light" (Zen23 V3 - fw:3.4) stopped responding to physical events. I can hear the relay trip when I flip the switch and the light goes on or off but nothing shows up in the logs or on the device page unless I hit the "refresh" command on the device page.
An Aotec Nano in the same box as the "Front Lamp Post Light" switch works as advertised while a Zen23 V3 dimmer switch in the same box as the "Side Porch Light" also works.
- I had no trouble pairing either switch. Came right up, was found - went with no authentication.
- physical toggling does nothing until I click on the refresh command on the device details page.
- On the device details page I can control the switches digitally - they respond as expected.
- On the device details page tried saving/saving preferences/configure etc etc. no go.
- I have 2 apps on this hub - Maker and HSM.
- I have 2 custom drivers - AeotecMultiSensor6 driver and the Basic Z-Wave Tool.
- I have no zigbee devices but the radio is on.
- I am not entirely sure the physical part was ever working since I usually control these through automation.
- I tried running a repair/refresh from the Z-Wave details page. Repair works fine according to the logs but behavior remains.
- I tried shutting down, pulling the plug, waiting then powering up - no go.
My next trick is to exclude and re-include the switches. Will report back what's going on.
