I am trying to add an action, run a rule action in another rule. It seems to be gone. I use the heck out of that, is there now another way to do that?
I found it... Am I crazy or did it move from where it used to be?
A couple of things may help me/others....
What platform version are you running?
If you could provide some screenshots of your rule / action you are trying to construct, that would be useful...
Not sure.... Where were you looking?
In 2.3.8.133 (current version at this moment), select "Set Private Boolean, Run/Cancel/Pause Rules", then select "Run Rule Actions".
This thread got me thinking…. Is there a straightforward way to find which rule(s) are running the actions of a given rule?
Nope. You could request that from @bravenel and perhapse such a capability could be added, but for now you could simply add to the Notes section of the rule so you know which rules are running its actions.
