Rules stopped working - Door Lock
I have two rules for the front and back door. Seperate
They are both a little different because back porch may have people out on the patio or pool area. This rule is based off light being on. Neither Rue is lockign the door.
IThe front door is based only off if its unlocked and closed. Required expression is door unlocked.
I'm not sure your can have the same condition as a required expression and trigger. It can't trigger until the required expression is true, and once the required expression is true, the trigger has already happened.
Your title says 'stopped working'. Did this work before? Logs from when the rule should have run would be helpful if you can post them.
I made whole sale changes to many rules recently.. I now think I may have added the " required epression to these recently"
I thought it would help things work better... Now I see it may have broke the rules themselves... I will remove them. Was trying to keep the hub quiet unless rules needed to be triggered.
