So I honestly don't know where to put this issue that I'm struggling with.
First I thought I have a zigbee problem, then I thought I had a driver problem, now i have A problem.
I've had many rules (Simple automation rules (SAR) / Rule Machine (RM) rules) working with SonOff SNZB-01 buttons, controlling my Shelly RGBW white lights or Shelly Dimmer2 lights.
Now the rules that have a simple short push don't work for toggle.
The rule is very simple - button1 is pushed (short push) and that toggles the light. No other conditions. This has stopped working altogether. The same Zigbee Button double click works flawlessly. I have multiple zigbee buttons around my living room that have the same exact functions and all of them exhibit this same behaviour.
Prior to this malfunctioning began, I've changed nothing.
I've tried to delete the rule and add it again from scratch.
I've tried to make the same rule in Rule machine.
Now comes what I don't understand:
- The push of the button is recognized / logged. But no action is performed
- It is only the toggle command that doesn't work. On or Off commands work for RM and SAR.
- I've now deleted all affected rules and instead of controlling devices, I've got it to send HTTP GET Shelly-IP-address/light/0?turn=toggle. That works great and faster than the toggle option ever has.
- the button "Run actions" in rule machine does not work either...
I run the latest platform 2.4.0.151.
Buttons use the internal driver "SonOff Zigbee Button Controller"
Shelly RGBW2 lights use Shelly RGBW White Shelly USA / Scott Grayban driver v. 1.0.1
Shelly Dimmer2 light uses Internal Shelly WiFi Dimmer driver.
Do you have any Ideas?
Thanks anyone in advance!
