I am having an issue with the script keeps running. I'm not exactly sure what to change or what condition to add.
If i open and close the door multiple times in a few minutes; it will go off 10 minutes later multiple times. I want it to just go off once. Even if the door is locked it will "relock" multiple times I'm guessing 10 minutes after I opened and closed the door.
I'd also like to add another setting where it checks every hour in the night from say 10pm-7am if its unlocked and to relock the door; if the door sensor is closed and the door is unlocked.
How do i Make the door cancel this trigger if the door is already locked? The notifications were not working when grouped together so I had to set them separate or the alexa would not speak.
