Wondering if anyone else has a more elegant way of doing this. I am trying to have different fan behaviours based on the status of the climate control. If my AC is on, I want my ceiling fans on less (because the cold air moving around gets to be a little much) however, if my climate control is set to off, then I want the fans to be more aggressive. I have 4 ceiling fans. Rule for all 4 are identical.
What do you think?
Select Actions for F - Bedroom Fan Automation
IF (Dining Room thermostatMode(cool) off(F) [FALSE])
THEN IF (Temperature of Master Bedroom(25.2) is < 23.0(F) [FALSE])
THEN Set Fan Speed: Bedroom Fan to off
ELSE-IF (Temperature of Master Bedroom(25.2) is > 23.0(T)
AND Temperature of Master Bedroom(25.2) is < 25.0(F) [FALSE])
THEN Set Fan Speed: Bedroom Fan to low
ELSE-IF (Temperature of Master Bedroom(25.2) is >= 25.0(T)
AND Temperature of Master Bedroom(25.2) is < 27.0(T) [TRUE])
THEN Set Fan Speed: Bedroom Fan to medium
END-IF
ELSE-IF (Dining Room thermostatMode(cool) cool(T) [TRUE])
ELSE-IF (Temperature of Master Bedroom(25.2) is > 27.0(F)
AND Temperature of Master Bedroom(25.2) is < 30.0(T) [FALSE])
END-IF
