Hi
I set a rule 4.0 for lights to turn on at sunset -30min and it works, but it also turn on the lights at SUNRISE -30min.
I can't find any settings for it, how do I solve it, any ideas?
Hi
Can you make a screenshot of the rule. You should be able to choose between sunrise and sunset.
Here is how I have my Porch light. Really don't know if this helps or not.
As said above though, you really do need to post a screenshot of the rule to get any meaningful feedback.
So what is turning the lights off for them to turn back on at sunrise - 30.
Do you have other rules for these devices?
Yea, I got 2 seperat rules for difrent lights.
This is my first attempt since I´m new so I´m probably using this the wrong way...
So I can't really figure out why all the lights went on this morning at sunrise...
There doesn't look to anything there that would do it.
Have you looked in the events for the devices that turned on? Does that give a clue?
How about past logs. Do they go back far enough to show what happened.
You could try combining them into one rule as a starting point.
I think this is the same.
