I have a rule that is basic and is based on light level. If it falls below a certain level then turn on the lights. The light level was well below the set limit and the rule said all was true. I had to open the rule and when I closed it the lights popped on.
Why would you have to open and close a rule to get it to work? How would it get stuck like that? This is an old rule that has been working fine for a long time.
Did you update the hub firmware recently?
Last week but it was running fine until today.
I think that when rule machine gets fixed with some firmware updates, some rules may need to be opened and closed like that to resume correctly. Seems like the timing doesnโt favor that explanation though.
I have read where some people have had to open/close them to reset them but how do you know which ones to open/close?
This is true, especially of any rule that has to do with Sunrise or Sunset. There's been a lot of changes in that area recently.
Generally, I think itโs when you have a rule that was impacted by a bug fix.
Yes I have seen quite a few posts on the sunrise/sunset problem. Luckily I don't have any with those selections. Hopefully they will get all the bugs fixed.
I always forget to look at the list of fixes they list. I am not used to having a list at all in HS. I will have to compare the list against any of the rules to see if they might match.
